Tire rotation...how often?
Old Feb 13, 2007 | 2:00 PM
Dash's Avatar
Default Tire rotation...how often?
I have an 07 LTZ with stock 20's.How many miles do you go between tire rotation? I am aware that the sensors for the tire pressure have to be reset. (Dave ZX...please give us your advice on this, thanks)
Old Feb 13, 2007 | 2:14 PM
engine2's Avatar
Default RE: Tire rotation...how often?
I rotate every 5K miles.
Old Feb 13, 2007 | 2:53 PM
shnormo's Avatar
Recomended every 6,000 to 8,000 miles. Every other oil change.
Old Feb 13, 2007 | 7:24 PM
ZX1100F1's Avatar
Tires should be rotated every 5,000 to 8,000miles (8000 to 13 000km). Any time you notice unusual wear, rotate your tires as soon as possible and check wheel alignment.
Also check for damaged tires or wheels.
Old Mar 24, 2008 | 12:48 AM
oniscus's Avatar
question? got this michelin jack from sams club 3 1/2 ton. what part can i use as a jacking point in the rear, the normal spot, the saddle of the jack is too big and wont sit properly on it. rear diff? what if i just want to raise one side?
thanks
Bryan
Old Mar 24, 2008 | 2:05 AM
bimmerborn's Avatar
I rotated at (5,000 + 8,000) / 2 = 6,500 miles !
Old Mar 28, 2008 | 7:32 PM
mary900's Avatar
'08 w/stock 20s -- every 7,500 miles.
Old May 3, 2020 | 7:57 PM
DWB's Avatar
DWB
Are the tires just rotated front to back or should they be crossed to the other side also?? Thanks.
I have an '06 Savana 2500 with A/T tires on it.
Old May 4, 2020 | 1:19 AM
if they are not directional tires you should cross the backs to the front and bring the fronts straight back. if you notice a pull after crossing tires...rotate back to the original side and do front to back only from then on.
you have part time 4wd.. 3/32 is the max different treadwear or you will stress the tcase in 4wd operation. rotation every 10 000kilometers keeps the tires within 1/32" which is ideal.
Ethan Northrop
Mar 12, 2019 6:16 PM
Whitts1
Sep 14, 2016 4:25 PM
ericnottelin
Aug 15, 2012 8:41 PM
jrowan123
May 17, 2008 10:47 PM
TahoeG8R07
Jul 24, 2007 10:06 AM
