Tires Skip when i turn sharp on 02 tahoe
Old Dec 20, 2013 | 5:41 PM
dsmitty26's Avatar
Default Tires Skip when i turn sharp on 02 tahoe
When I turn the wheel sharp either direction the tires skip like it's in 4wd but its not, I brought it into the dealership where I just bought it and they put it up on the lift and said nothing is sticking or catching, is this a common problem with the 02 Tahoe and if not any possible ideas on what it might be? Thank You!
Old Dec 20, 2013 | 6:14 PM
Welcome to the forum..
is it the front or rears , do you have really large tires...
Old Dec 20, 2013 | 6:21 PM
dsmitty26's Avatar
It just has the regular size tires on it
Old Dec 20, 2013 | 7:11 PM
might want to have an alignment check. If the suspension components are all tight, you could have a toe issue.
Secondly, while an alignment is being done have them check toe out on turns or Ackerman's angle. This angle is designed into the steering knuckles and cannot be adjusted. If toe out on turns is out of spec. the knuckles are probably bent.
typically the front tires scrub during tight turns when Ackerman's angle is out of spec.
Old Dec 20, 2013 | 9:20 PM
dsmitty26's Avatar
Ok Thank you!!! I will have those things checked out
Old Jul 24, 2016 | 1:40 AM
Mike Jefferson's Avatar
Is there a reason for this problem besides bent knuckles. I took my truck to three mechanics and none of them have a solution.
Old Jul 24, 2016 | 8:51 AM
if your issue is the front tires scrubbing when the steering is turned to the stops; have the alignment checked.
if your referring to axle bind-up during tight turns in 4wd; that is a normal condition.
Old Jul 24, 2016 | 9:39 PM
Scotiapilot's Avatar
Sounds like "crow hop" from your 4x4
Old Jul 24, 2016 | 10:45 PM
I had it computer aligned to factory specs. Its like it was set up for reverse ackerman. It toes in at full turn, both left and right. Im wondering if the pro comp lift kit has something to do with this.
Last edited by Mike Jefferson; Jul 24, 2016 at 10:47 PM. Reason: added a couple sentences.
Old Jul 24, 2016 | 11:46 PM
post the alignment printout that you have.
have them check and measure toot with the alignment machine. you can have them measure ackermans angle and plot toe change as it sweeps stop to stop.
