Tires Skip when i turn sharp on 02 tahoe
When I turn the wheel sharp either direction the tires skip like it's in 4wd but its not, I brought it into the dealership where I just bought it and they put it up on the lift and said nothing is sticking or catching, is this a common problem with the 02 Tahoe and if not any possible ideas on what it might be? Thank You!
might want to have an alignment check. If the suspension components are all tight, you could have a toe issue.
Secondly, while an alignment is being done have them check toe out on turns or Ackerman's angle. This angle is designed into the steering knuckles and cannot be adjusted. If toe out on turns is out of spec. the knuckles are probably bent.
typically the front tires scrub during tight turns when Ackerman's angle is out of spec.
I had it computer aligned to factory specs. Its like it was set up for reverse ackerman. It toes in at full turn, both left and right. Im wondering if the pro comp lift kit has something to do with this.
Last edited by Mike Jefferson; Jul 24, 2016 at 10:47 PM. Reason: added a couple sentences.
