Tools for Strut Top Nut
Old Aug 23, 2019 | 8:36 PM
kshouman's Avatar
Default Tools for Strut Top Nut
Can anyone tell me the right tools to use to remove the top nut from the struts from a 2009 Tahoe? It is a 18 mm nut but is down in a hole and I need some way to hold the shaft while loosening the nut.
Thanks for the help.
Old Aug 25, 2019 | 11:23 AM
This is what I did... see this thread https://chevroletforum.com/forum/tah...acement-60220/
Old Aug 25, 2019 | 5:56 PM
if the old strut is garbage, clamp a vise grip on the strut rod between the spring coils. if you need to reuse the strut...I use a pass thru socket set. make sure you are using a good spring compressor...truck springs are strong.
stephen kamphaus
Avalanche
Nov 20, 2016 7:22 PM
MyBowTieGuy
May 22, 2015 12:41 AM
BAGnDRAG-K5
Jul 21, 2010 1:41 AM
madmaxx1
Jul 28, 2009 3:26 PM
goingmyway
Sep 16, 2007 5:45 PM
