Towing an LTZ
Old Oct 13, 2007 | 10:43 PM
07summitwhite's Avatar
Default Towing an LTZ
Is there a switch to shut off the auto-ride on the LTZ when getting towed?
Can you tow it without it being shut off?
Old Oct 13, 2007 | 11:18 PM
engine2's Avatar
Default RE: Towing an LTZ
No switch that I am aware of. I would highly recommend using a flatbed. Good Luck
Old Oct 13, 2007 | 11:33 PM
I don't need it towed, but I seen in a AAA towing manual that the 2007 tahoe/suburban needs to have the auto-ride shut off and there was a switch to do so. I never seen it in my GM manual hough.
Old Oct 13, 2007 | 11:52 PM
engine2's Avatar
Very interesting. I have not seen a switch or heard of oneon mine either. Try PMing zx1100f1. He would definitely know. Now I am curious
Old Oct 13, 2007 | 11:57 PM
vehview
Old Oct 14, 2007 | 2:12 PM
tahoe07's Avatar
Need to log in to use that site. Can you just paste the material for all to see?
Old Oct 14, 2007 | 2:23 PM
I though that you coulsn't copy and paste on this site?
Old Oct 14, 2007 | 8:42 PM
weewun's Avatar
I hope I am not in trouble, I tow my 07 LTZ behind my MH all the time and have not experienced a problem that I know of. I follow the directions in the manual which states to put the Transfer Case in Neutral, shift to Reverse then Drive, shut-off engine, shift to Park and remove the key. No where does it say anything aboutturning off the auto-level.
I suppose if you really wanted to disable the auto-level you could remove the fuse.
What is supposed to happen if you tow without diabling the auto-level????
Old Oct 14, 2007 | 8:57 PM
I'M not sure what if anything will happen on the Chevy, but I know on any Lincoln if you leave the air-ride on and you tighen the suspension down when towing, the compressor will try and fill the air bags back up to level the car/truck resulting in all the air bags blowing. I know it's something like a $2,000.00 per bag repair on a Lincoln.
The Auto-Ride in the Chevy works the same way as the Lincoln trying to keep the tahoe/suburban level when towing a heavy trailer. Will it stay engaged with the key off?
Old Oct 14, 2007 | 9:45 PM
ORIGINAL: 07summitwhite
I think you hit the nail on the head. I know on mine, the compressor doesn't level the truck after I hook/unhook my jetski trailer until after I start it up.
{tpc}
Jun 28, 2014 2:34 PM
bigodr
Aug 2, 2012 12:50 AM
D-Train
Mar 28, 2012 7:47 AM
Nyron
Jun 28, 2010 10:55 AM
ahjah9
Dec 7, 2006 10:20 PM
