TPS Disable???
Old Feb 10, 2010 | 8:47 AM
suitedandbooted's Avatar
Default TPS Disable???
Is there any way to disable the TPS sensor so the light is not always on? I have aftermarket wheels and could not get the TPS sensors to work and instead of messing with it I owuld rather just shut them off.
Old Feb 10, 2010 | 12:28 PM
vester's Avatar
The general consensus I have seen is that is impossible to disable the system because it is federally mandated. However, you could pull your dash apart and either remove the light or black out the TPMS sensor indicator from the back so that you could not see it.
I have stock wheels on my truck and on my wife's Subaru. Both TPMS systems still drive me crazy in the winter because of the temperature related tire pressure variations.
Old Feb 10, 2010 | 7:52 PM
rruelas's Avatar
If you do a search, i believe that one member got a small tire and rim like for a riding lawnmower had 3 extra holes drilled in the rim, and had all four of his factory sensors mounted in there and put the small tire under the spare.
I think that you can order a different type of TPMS or grommet and mount it in the aftermarket rim if the factory ones don't fit. You can also look up TPMS mounting bands that will allow you to mount your sensors in the rim itself. hope this helps
Old Feb 11, 2010 | 12:05 PM
Why not just put the TPMS sensors in a Ziploc bag and throw it in the back?
fernandito7
Oct 3, 2007 5:08 PM
EliteDetailOC
Mar 27, 2007 12:13 PM
bobbyt
Mar 14, 2007 7:24 PM
EliteDetailOC
Mar 13, 2007 2:30 PM
amos221
Mar 6, 2007 10:41 AM
