Tranny will not engage into any gears.
Old Apr 8, 2011 | 8:16 PM
gpro's Avatar
Default Tranny will not engage into any gears.
Hello all,
I registered here today hoping I can get some good advice regarding my transmission issue. I was lurking here before and found some good threads which help me fix my AC issue. I have search a bit and I didn't find anything that had the same symptoms as my tranny. Here is the background and the problem.
I ran my suburban's 4wd lo at 30mph and it overheated the transmission. Some transmission fluid started spilling out. I was able to get it back to my driveway and I drove on 2 hi for a couple of days with no problem. Today, the gear will not engage. There is a sound like it's engaged but when I give it some gas, the car doesn't move. It feels like the ebrake is on. Any ideas?
Thanks
Rommel
Old Apr 8, 2011 | 10:34 PM
Welcome to the forum.
Is the transfer case in Neutral?
Old Apr 10, 2011 | 9:19 AM
gpro's Avatar
nope. I can see the selector lever arm move when I change gears
Old Apr 10, 2011 | 12:45 PM
gpro's Avatar
After a closer look, I noticed a hole in the torque converter cover. What does this mean and will this need a comple transmision rebuilt?
Old Apr 11, 2011 | 7:51 AM
vrso2's Avatar
well, first of all, u should change all trany fluid and filter.I prefer to complete flush, not just 4 quarts. Then try again.
Old Apr 11, 2011 | 10:51 AM
Official GM Rep
gpro, what is the model year and mileage of your vehicle? I would like to see if I can assist you.
Jeff Morris, Chevrolet Customer Service
Old Apr 11, 2011 | 11:53 AM
technicauto's Avatar
Its sounds like your transfer case is in neutral.
Old Apr 11, 2011 | 9:43 PM
gpro's Avatar
Thanks for all the help so far. I just picked up the transmission filter kit and 7 quarts of transmission fluid. My vehicle is a 97 Suburban with 160000 miles on it. How can I tell my transfer case is on Nuetral if I have an electronic push button transmission? I can see a light on 2Hi and I can change it to 4Hi and the lights stays lit. Is there a way to tell from looking under the truck if it's on Nuetral?
Thanks again for all the help.
Newto4x4
Nov 3, 2022 8:18 AM
Chester the tahoe
Apr 18, 2015 9:28 PM
Junkin8ez
Jan 25, 2015 2:33 PM
donbrearley
Jun 26, 2013 10:26 AM
squarepeg
Apr 8, 2010 7:18 PM
