Trans oil cooler
Old Mar 1, 2020 | 2:27 PM
1st Officer's Avatar
Default Trans oil cooler
Forgive me if this question has already been answered but i did not see that it had been addressed so here goes.
I have a 2008 tahoe ltz. My transmission went out a few months ago and my engine threw a code that suggests the timing chain is failing. I know that the 2 issues are unrelated, but since i have both to address i have opted to replace both engine and trans with remans from powertrain. my question is regarding the trans. . .is it necessary to replace the trans oil cooler when i replace the trans or can it be flushed. The trans failing was not accurately diagnosed and after wasting 700.00 on a repair attempt i decided to cut the losses and just replace it. So i dont know if the fluid is contaminated or not. Any heads up would be appreciated.
Old Mar 1, 2020 | 3:42 PM
kevinkpk's Avatar
Not familiar with your setup, but, if the transmission failed, I'd either replace the cooler, or remove it,and have it flushed seperate. IMO.
Old Mar 1, 2020 | 4:58 PM
Little Bear's Avatar
Stacked plate coolers like the factory uses can not be properly flushed and must be replaced, at least that is my understanding.
Old Mar 1, 2020 | 5:10 PM
Rednucleus's Avatar
Your cooler is not part of the radiator?
Old Mar 1, 2020 | 5:42 PM
it has a separate cooler that is attached to the radiator but runs a separate set of lines in n and out of trans
Pugly
Jun 16, 2014 9:07 AM
wickedchev
Nov 30, 2012 12:03 AM
white bear
Jan 22, 2011 12:35 PM
taxifolia
Jan 9, 2011 2:18 PM
Stoneybroke
Jun 23, 2010 8:17 PM
