Transmission advice
Old Feb 5, 2013 | 4:28 PM
Coltronist's Avatar
Default Transmission advice
How's it goin, I've got a 73 chevy with an 83 body and an edelbrock 383 stroker with a turbo 400 transmission. The transmission is bad and needs to be replaced, so here is my question, I'm thinking of converting the car from a 3-speed automatic to a 5or6-speed manual, is it worth it? I've got the money for it, OR do you recommend a tranny for me to put in there, thanks!
-Colton V
Old Feb 7, 2013 | 5:58 PM
Ghetto Burb's Avatar
I personally wouldn't do it, it sounds like you have an interesting project and I would guess you use it for a little off roading? The standard will hold you back a little and compound problems that you could run into. I'm speaking from experience, I had an 85 CJ that I put a 400 small block into and maintained the standard transmission for the first month or two, shortly after that I switched to a turbo 350 and was way happier. Better throttle response more off road control and made it unbeatable on the street. Just my 2 cents though.
Good Luck
Glenn
inbizness
Feb 25, 2013 9:51 PM
Dakota_Don
Nov 26, 2010 2:45 PM
ezadda
Jan 18, 2010 8:26 PM
jason_f
Dec 1, 2007 3:08 PM
Guitarfallon
Feb 21, 2007 1:09 AM
