Transmission leak questions 02 tahoe
Old Aug 22, 2011 | 1:34 PM
soloblazer's Avatar
Default Transmission leak questions 02 tahoe
i have a friend who has a 02 tahoe 5.3l 2wd.
Just had a used tranny put in it, and shifts good, but when you park on a incline it leaks fluid out the rear of tranny where the drive shaft goes in, i know there is a seal there, so my question is how hard is it to change that seal and should i change anything else while in there. it leaks pretty good when on big incline. but not when flat, just a drop or two. thanks
Old Aug 22, 2011 | 3:29 PM
kevinkpk's Avatar
That is easy. However I'd check the fluid level. If you have to replace the seal, drop the drive shaft, and pop out the seal, then drive in a new garlock seal.
Old Aug 22, 2011 | 3:45 PM
soloblazer's Avatar
ok, can to much fluid cause it to leak out the back like that?
soloblazer
May 22, 2013 7:15 PM
tblt44
Jun 22, 2010 8:29 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
Colt Hero
Dec 17, 2006 10:57 AM
