True Flow Intake
Old Oct 27, 2007 | 1:45 AM
bigblackchevy's Avatar
Default True Flow Intake
Hello All,
Has anyone used the True Flow Intake? I stubled across this intake while researching Volant and S&B.
Thx
Old Oct 27, 2007 | 7:47 AM
thdrill's Avatar
Default RE: True Flow Intake
I recently put one in my 2003 hoe, but still on the first tank so hard to fig out any effect on MPG. However, it does give a nice sound with faster acceleration and it seems I don't have to push the pedal down as hard to get my Tahoe to start moving. But, it sounds pretty well stock with constant speed. Will post when I see what happens to fuel economy.
Old Oct 27, 2007 | 1:36 PM
GIXXER's Avatar
There are a few Tahoe's in this forum with the trueflow and their comments sound very positive.I believe there is a post, that you'll have to search, which discusses the XDITrue FLow. If you check out the True Flow website there are also really good videos that adda lot of merit to using a foam filter instead of paper based filters.
Old Oct 27, 2007 | 4:18 PM
I saw one or two and you are correct, they are positive. I've searched some other forums and everything seems to be positive. I think I'm going to persue the sealed box option.
I talked to one of the guys at the Chevy ProShop. He told me he has sold and personally used the Tru Flow Intake as well. He also suggested that I get AirRaid throttlebody spacer.
Now I'm on the hunt for a good deal
Thx!
Old Oct 27, 2007 | 10:30 PM
thdrill's Avatar
what would be the purpose of the throttle body spacer
Old Oct 27, 2007 | 11:05 PM
The TBS spins the incoming air charge, boosting velocity for improved atomization. The end result is improved combustion efficiency which boosts low-end torque, throttle response, and fuel efficiency. Admittly this is a hit or miss opportunity. The Tahoes have seen more hits than misses supposedly. I know I've seen posts where people have said save your $ so I'll take the hit for the team
Old Oct 27, 2007 | 11:33 PM
ORIGINAL: bigblackchevy
If swirling the air is such a good thing, then why have we wasted all of that money polishing intakes to make for smooth air flow. Carb spacers were used to move the hp up in the rpm band. Didn't really add much tho. Since on FI the fuel is injected right at the head of the valve, I doubt the air is really "swirling" by the time it gets that far.
Old Oct 28, 2007 | 1:34 AM
GIXXER's Avatar
"The throttle body spacer causes the incoming air charge to tumble for better atomization of the mixture downstream in the combustion chamber.
In other words a throttle body spacer will yield a much greater fuel burn efficiency, which in turn will improve performance and improve fuel economy" -- http://throttlebodyspacer.com/
Old Oct 29, 2007 | 9:35 PM
Well I guess that settles it then. Be nice to see some third party data supporting their claim.
Old Oct 30, 2007 | 11:47 AM
TallyDAWG's Avatar
How is your search coming? Did you end up with the XDI or sealed?
Thx!
