turn off daytime running lights on '01
Old Feb 28, 2007 | 10:56 PM
peacekeeper's Avatar
Default turn off daytime running lights on '01
Is there some secret to turn off the day time driving lights when you are parked and the engine is running??? My old 97 'Burban, I could click in the parking brake one click and the daytime running lights would turn off...is there a simular trick for my '01???
Old Mar 2, 2007 | 4:28 PM
Default RE: turn off daytime running lights on '01
FYI, I found on another forum that pushing the dome light override button 3-4 times will disable the DRLs for the time that you have the ignition switch on. I sooo glad I found that out, I hate parking with the truck running and having the stupid DRLs on.
Old Mar 18, 2007 | 2:16 AM
My wife's 2004 Tahoe DRLs can be turned off by rotating the lite switch counter-clockwise and releasing. Not sure if that'll work on '01s.
Old Mar 22, 2007 | 12:10 PM
bracing248's Avatar
I've got a similar situation with my '96 Suburban. Just the other day I noticed the daytime running lights weren't on and the dash indicator light was lit. I checked the parking brake and all the fuses related, according to the manual, to the DRL circuit. Am I missing something else, all other lights and auxillary are working fine.
Any help.
Old Mar 22, 2007 | 5:13 PM
RonH's Avatar
Did you check the relay in the under hood fuse box ? There's a fuse and a relay in there for the DRL.
Old Mar 23, 2007 | 12:24 PM
bracing248's Avatar
I appreciate the help. I did pull and check each fuse in the under the hood box and swapped out the fuse labeled as 'lighting'. As far as relays, non of them are labeled DRL, of the four relays two are for diesel system and remaining two I swapped and had no success.
Old Mar 26, 2007 | 10:50 AM
bracing248's Avatar
update. bought and replaced relay for DRL. Not it, I can't believe what a pain this is.
Old Mar 17, 2010 | 2:00 PM
BTJames's Avatar
I have the same problem with my '96 Tahoe. Did you ever get it fixed? Thanks
RitualJman
15
Apr 22, 2026 9:15 PM
LTZ_HOE
Jul 5, 2025 7:00 PM
irishflies
Jan 9, 2007 10:56 AM
stingray502
Oct 25, 2006 12:31 PM
