Turn signal issue '02 Tahoe
Old Jan 19, 2008 | 1:35 PM
nukeflash's Avatar
Default Turn signal issue '02 Tahoe
Last week I started to have a problem with the turn signal in my 2002 Tahoe Z71. All of the lights would flash rapidly, and the side I was activating would burn the brightest. The rear Cyclops light also flashed. Immediately I replaced the flasher under the dash, that didn't work. Armed with a lot of information, I decided to order a new turn signal and install it. THAT DIDN'T WORK EITHER!! After some addition trouble shooting, I discovered that the problem ONLY happens when the parking lights (or headlights) are on. That is even weirder!! I have removed EVERY relay and fuse related to those lights. It doesn't fix it. Although... when I removed the fuses for the front parking lights, the problem slowed and seemed better. Then I removed the rear parking lights, that ALMOST made it stop, but there was still a faint flashing of the other turn signal flashers on the opposite side. PLEASE HELP!!!
Old Mar 18, 2008 | 6:37 PM
07burbman's Avatar
Default RE: Turn signal issue '02 Tahoe
you have a wire that is grounded out causing the lights to flash.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
nukeflash
Nov 16, 2014 12:04 AM
RomanGuzi
Oct 2, 2011 11:40 AM
nukeflash
Jan 20, 2008 2:51 PM
dmtcrainey
Jan 8, 2008 10:41 PM
