Two-way remote update
Old May 31, 2008 | 10:44 AM
Default Two-way remote update
Pulled this off another forum:
GM ACCESSORIES - TO BUICK, CADILLAC, CHEVROLET, GMC, HUMMER AND PONTIAC DEALERS
Subject: Bulletin ACC08-020 - New Accessory! Dealer-Installed 2-Way Advanced Remote Start
Message #: VSE20080443
DESCRIPTION:
Introducing the innovative 2-Way Advanced Remote Start. Now available for select GM vehicles (see below for detailed vehicle application information). The 2-Way Advanced Remote Start allows customers to upgrade their factory keyless entry or factory remote start systems to provide enhanced functionality. In addition to extended range remote keyless entry*, extended range remote vehicle start, and standard functions like door lock/unlock, vehicle locator/panic alarm and power liftgate open/close (if vehicle is equipped), this new accessory also features technology that allows 2-way communication between the key fob transmitter and the vehicle.
The key fob transmitter provides immediate visual and audio confirmation that a key fob command (like start vehicle, lock/unlock doors, etc.) was received. The large, easy-to-read LCD screen displays status/data when within range of the vehicle such as Fuel Level, Tire Pressure, Odometer Reading (accurate within 1 mile), Clock/Remote Start Countdown Timer, and Key Fob Battery Life Indicator. Customers with vehicles equipped with steering wheel controls (UK3) can even scroll through their pre-set radio stations.**
* Up to three times as far as factory remote keyless entry
** excludes HHR and G6
EFFECTIVE DATE:
Immediately for all vehicles listed below except HHR. The 2-Way Advanced Remote Start for HHR will be available shortly.
QUALIFICATIONS:
Fits specific makes/models (see below for details).
ORDER INPUT:
Orders can be placed through your local Accessory Distributor Installer (ADI), or through your Parts Department to be charged against the open parts account.
Part Number Product Description:
for vehicles... Product Usage
Year - Make - Model MSRP Install Time
17802088 With AP8 (extended range remote keyless entry) and E61 (power liftgate) 2008 Buick Enclave
2007-2008 GMC Acadia $250.00 1.9 hrs
19156554 With AP3 (factory remote start) and E61 (power liftgate) 2008-2009 Buick Enclave
2007-2009 GMC Acadia $150.00 1.4 hrs
19171128 With AP8 (extended range remote keyless entry) and automatic transmission, without E61 (power liftgate) 2007-2009 Chevy Silverado Regular Cab (-C49)* & Crew/Extended Cab (-A48)**; Avalanche, Equinox
2007-2009 GMC Sierra Regular Cab (-C49)* & Crew/Extended Cab (-A48)**
2007-2009 Pontiac Torrent $250.00 1.9 hrs
19171129 With AP3 (factory remote start), without E61 (power liftgate) 2007-2009 Cadillac Escalade EXT
2007-2009 Chevy Silverado Regular Cab (-C49)* & Crew/Extended Cab (-A48)**; Tahoe Hybrid (+HP2); Avalanche, Equinox
2007-2008 GMC Acadia, Sierra Regular Cab (-C49)* & Crew/Extended Cab (-A48)**; Yukon Hybrid (+HP2)
2008-2009 HUMMER H2 SUT, SUV
2007-2009 Pontiac Torrent $150.00 1.4 hrs
17802087 With AU0 (remote keyless entry) and automatic transmission 2007-2009 Chevy Silverado Regular Cab (-C49)* & Crew/Extended Cab (-A48)**
2007-2009 GMC Sierra Regular Cab (-C49)* & Crew/Extended Cab (-A48)** $295.00 2.2 hrs
19157233 With AP8 (extended range remote keyless entry) and E61 (power liftgate); excludes Hybrids (-HP2) 2007-2009 Chevy Suburban, Tahoe
2007-2009 GMC Yukon, Yukon XL $250.00 1.6 hrs
17802071 With AP8 (extended range remote keyless entry) without E61 (power liftgate); excludes Hybrids (-HP2) 2007-2009 Buick Lucerne
19156555 With AP3 (remote vehicle start) without E61 (power liftgate); excludes Hybrids (-HP2) 2007-2009 Buick Lucerne
2007-2009 GMC Yukon, Yukon XL $150.00 1.1 hrs
19157237 With AP3 (remote vehicle start) and E61 (power liftgate); excludes Hybrids (-HP2) 2007-2009 Cadillac Escalade, Escalade ESV
2007-2009 GMC Yukon, Yukon XL, Yukon Denali, Yukon XL Denali $150.00 1.1 hrs
17802069 With AP8 (extended range remote keyless entry) 2007-2009 Pontiac G6 $250.00 1.9 hrs.
19156553 With AP3 (remote vehicle start) 2007-2009 Pontiac G6 $150.00 1.6 hrs.
19157234 With AP3 (remote vehicle start) 2007-2009 Chevy HHR (excludes all Panel models) $150.00 1.7 hrs
* -C49 = Without Rear Defogger
** -A48 = Without Power Sliding Rear Window
GENERAL INFORMATION:
Antenna location varies by vehicle make/model.
Key fob can be programmed to control a second vehicle if that vehicle is also equipped with 2-Way Advanced Remote Start.
If reprogrammed, factory key fobs remain operational (except HHR & G6; 2-Way Advanced Remote Start kits for these vehicles include one new factory-style key fob to replace the factory fob).
To preserve battery life of the 2-Way Advanced Remote Start key fob transmitter, the image on the screen remains illuminated for approximately 5 seconds. To recall image to the screen, simply press any button once. To illuminate backlighting, press one of the side buttons once.
Important Installation Information:
• Estimated installation time: 1.1 – 2.3 hours, depending on vehicle
• Installation instructions available via Service Information (SI) website
• Requires service programming and scan tool
• Adhesion promoters are not included in kits. Order GM part number 12378555 for glass surfaces on '08 HHR and all full-size SUVs, or
12378462 for all other surfaces on all other vehicles.
• G6 requires a small piece of felt/flocking tape which is not currently included in the kit. Call 1-800-654-6333 to order BSR part number KT13296.
GM Accessories permanently installed at the time of new-vehicle delivery are covered under the New-Vehicle Limited Warranty. If installed after delivery, coverage (parts and labor) is for the balance of the New-Vehicle Limited Warranty, but not less than 12 months or 12,000 miles (whichever comes first). GM Accessories not requiring installation or purchased over the counter carry a 12 month limited warranty (parts only).
This product is also covered under GM Protection Plan (GMPP) Major Guard and Smart Protection vehicle service contracts. Please refer to the current GMPP administrative guide for coverage details.
If you have additional questions, please contact your District Parts Manager (DPM) or Regional Division Marketing Manager-Accessories (RDMM-A).
One guy got a $250 quote installed at the dealer.
Old May 31, 2008 | 11:21 AM
Default RE: Two-way remote update
Thanks shark for the legwork, I have the remote start option and have wanted to get it enabled and was waiting for this keyfob...
I wonder why the w/power liftgate is less then the one without...
Old May 31, 2008 | 12:42 PM
BMoTahoe's Avatar
Uh oh, gotta get one.
Old May 31, 2008 | 1:02 PM
Guessing its still this one?
[IMG]local://upfiles/17388/40C67070F1C94599AC947B8FB5ECC5F5.jpg[/IMG]
Old May 31, 2008 | 6:06 PM
yep my local dealer carries it http://gm.oeaccessories.com/hennachevy/
Old Dec 11, 2015 | 5:36 PM
Jncfreer's Avatar
Talking 2 Way Remote add-on advice for 2007 LTZ
Hey-
I have a 2007 LTZ and am interested in adding this 2 way remote #19157237 (I've checked and I believe I have the right part number).
The Whole purpose in adding this remote is 2 fold: 1) to increase the distance to which I can start my Tahoe vs the currently installed factory version.... and 2) be able to get it to run FOR MORE THAN THE 5 MINUTES it is currently programmed for....
At any rate.... My questions are these... Can I install this myself (currently I am mechanically inclined enough to know I need to ask first...)? I understand I have to go to the dealer to program the system.... But, will the current 5 minute "Time-Out" be changed when the new 2 way remote is reprogrammed?
It makes "NO SENSE" to me to be able to start the Tahoe from farther away, if I have to go back out AGAIN to have it start for another 5 minutes !!
.. I live in Alaska people.. 5 minutes was fine when I lived in California, but in Alaska I need at least 10 to 15 minutes to start my car and have it warm up when it is 10' outside.
Any (reasonable) suggestions are appreciated.
Thank you. I appreciate you very much,
J
Old Dec 11, 2015 | 7:22 PM
iirc all that is changed is the rcdlr and a larger antenna is installed. the dealer will have to do the reprogramming events as the updated program must added to the dealer server for your build. you get one 2way remote but they can program your old fobs so they will still work.
not sure on the run time.
Old Dec 12, 2015 | 11:25 AM
Jncfreer's Avatar
I did find out 1 thing.... the Dealer was able to confirm that the run time will change to 10 minutes... then you can restart for another 10... but after that... you will have to use the key itself to start and then drive the Tahoe.
Anyone have another system that works better? Or something that beats what GM offers?
Thanks
J
jameslaz
Oct 1, 2019 1:16 PM
jlenkows
Jan 22, 2008 6:15 PM
tbrend
Oct 18, 2007 12:42 PM
biglg
May 15, 2007 11:09 PM
