Water Leak from Passenger Visor
Old Oct 24, 2022 | 11:22 AM
CB2003Suburban's Avatar
Angry Water Leak from Passenger Visor
I have a 2003 Suburban with a sunroof and when it rains there is a drip from the passenger side visor where the visor mounts to the roof panel. It leaks on the door side mount. I'm guessing its from the sunroof, but is there a way to find out/repair the leak?
Thanks,
Chris...
Old Oct 24, 2022 | 11:25 AM
You will need to replace the sunroof weatherstripping and also check for and repair rust under and around the weatherstripping.
Old Oct 24, 2022 | 12:38 PM
Sounds good. I will do some research on how to replace the weather strip.
Thanks for the help..
Chris...
Old Oct 24, 2022 | 2:17 PM
Also you might check the drains to make sure that they're not plugged up with anything.
Old Oct 24, 2022 | 5:10 PM
The drains sound like an easier fix. I checked the gasket and it looks good. Where are the drains located? How can you clean them out? A compressor and a blower?
Old Oct 25, 2022 | 7:58 AM
repairman54's Avatar
The drain tubes will not stay connected with a blast of compressed air. Yours leaking by the visor means the drain tube probably came off the sunroof housing.
Have to pull down the headliner slightly to take a look at it.
Old Oct 25, 2022 | 10:39 AM
Jason PM's Avatar
My 2003 Suburban started leaking a few years ago. It was due to the windshield gasket. It had started to separate from the roof panel above the windshield. I filled the space with silicone. All good after.
chevygirl2020
Apr 28, 2025 9:26 PM
Wavelength
Aug 6, 2022 3:46 PM
starsrocket
Jun 27, 2019 10:57 PM
mountainmanjoe
Jul 2, 2017 8:43 PM
