Weird transmission/ electrical problem
Old Dec 24, 2021 | 1:11 PM
kentolla's Avatar
Default Weird transmission/ electrical problem
My transmission went out in my 2010 suburban around thanksgiving, we had replaced the tranny a year ago so it was under warranty. The shop that put in the new transmission called me, I picked up the vehicle and noticed it was shifting more like it was in tow mode and at regular shift intervals. I drop the gear shifter down into the manual shift mode, and on the instrument cluster nothing changed, it acted as though it was still in drive. I tried hitting the tow mode button, and nothing happened. I took it back to the shop, they ran all the wire and ran diagnostics again and said their best guess was that it was a BCM (they said it was also throwing code P0826). I took it back I installed a new shifter, because I had seen where some of the wires on other peoples gear shifters had broken and mine were getting close. That did not fix it. I ordered a new BCM pre-programmed and installed it today, and still it’s not working. I’m at a loss, it almost feels like to me the transmission was programmed faulty, but the shop wouldn’t even listen to that suggestion. Has anybody ever experienced anything like this? Could a faulty connection into the transmission because in this problem? Any suggestions? I’d rate myself a novice when it comes to mechanicing.
Also I do know that these features were working before I took the vehicle to them. Because I have been using the manual mode to shift since the transmission was going out.
Old Dec 25, 2021 | 8:42 AM
repairman54's Avatar
|P0826 CHEVROLET code possible causes
  • Check other engine related codes first
  • Faulty Engine Control Module (ECM)
  • Engine Control Module harness is open or shorted
  • Engine Control Module circuit poor electrical connection
  • Faulty Transmission Control Module (TCM)
|What is P0826 CHEVROLET code meaning?
The Automatic Transmission Control Module (TCM) receives transmission-related information from the Engine Control Module (ECM) via serial data. When the ECM receives invalid transmission-related information, it notifies the TCM. The TCM then sets the appropriate Diagnostic Trouble Code (DTC).
Old Dec 25, 2021 | 11:45 AM
hanky's Avatar
Unfortunately , your trans shop either is not equipped to troubleshoot this problem or doesn't want to.
John21851
May 27, 2021 7:03 PM
jbfoster
Oct 6, 2019 12:39 PM
justin richter
Jan 5, 2017 11:04 AM
TDSSD
May 7, 2013 3:25 PM
TBarwick1
Jun 3, 2007 10:59 AM
