What are these little speakers???
Old Apr 22, 2013 | 6:17 PM
Rocker's Avatar
Default What are these little speakers???
What are the little speakers for by your head in the headliner? There is one in the front over the driver door by your head and one in the back on the same side..
I am asking because they are buzzing.. and wont stop. very annoying.. any ideas..
2003 Suburban 4x4.
Old Apr 22, 2013 | 6:41 PM
Those aren't speakers... they are Inside Air Temperature Sensors for your HVAC system..
File Type: pdf
Old Apr 22, 2013 | 6:49 PM
Rocker's Avatar
any idea why they are making noise?
and would you say they need replacing?
Thank you for your information.
Old Apr 22, 2013 | 8:13 PM
Joe In NY's Avatar
The rear one in our 2007 makes noise like a fan hitting something.... I want to know what's inside as well...
Old Apr 22, 2013 | 9:14 PM
I have not had one opened up, but I suspect it is a fan and a sensor. Might try removing and inspecting.
Old Apr 23, 2013 | 7:45 AM
Rocker's Avatar
Default sensor
I opened mine up and your right there is a small circut board and a fan and a little sensor. Not sure why it would make noise, the fan does not appear to when you spin it.. it appears to be fine..
Here is the part number below.. from GM Direct..
Its called an Aspirator and found under the HVAC section.
<TABLE border=0 cellSpacing=0 cellPadding=5 width="100%" align=center><TBODY><TR><TD noWrap>Old Part Number</TD><TD align=right>15029252</TD></TR><TR><TD noWrap>New Part Number</TD><TD align=right>20931026 </TD></TR><TR><TD>Part Name</TD><TD align=right>Aspirator EXTENDED CAB, HEADLINER & COMPONENTS </TD></TR><TR><TD>MSRP</TD><TD align=right>$47.98</TD></TR><TR><TD>Online Price</TD><TD align=right>$24.95</TD></TR></TBODY></TABLE>
Old Apr 23, 2013 | 10:11 AM
I'd be my guess that the fan bearings are worn/wearing out thus causing the sound you hear....might check your local dealer as they may match the GM parts direct price and it will save you the shipping.
Old Apr 23, 2013 | 3:29 PM
Might try applying some lite oil to bearings and retry to see if that helps. I know it works on blower motors.
Old Apr 23, 2013 | 11:00 PM
Joe In NY's Avatar
Haha. Well I don't know if you mean hvac blowers or boat blowers. But I have saved several boat blowers by cleaning them and using a few drips of mobile 1 into each end. Each one I have done it to shut up right away and stayed quiet.....
Ertsride1
May 9, 2008 1:35 AM
crazy_wog01
Jan 1, 2007 7:17 AM
Kaznasty
Dec 19, 2006 9:01 PM
biglg
Nov 29, 2006 11:53 PM
03z71Tahoe
Apr 19, 2006 1:17 AM
