what is up with the timing
Old Sep 11, 2006 | 8:41 PM
jsshark1's Avatar
Default what is up with the timing
I have a 96 with a 5.7 V8, i blew a intake gasket last week, water just coming out of the intake.
I got it all back together and i am ready to time the distibitor and the tag tells me thier is no ajustment and the computer will do that and the idle. i have unpluged the plug behind the distibitor and i still cant get the timing to go to -0-. the truck runs good. I am worried that thier maybe no ajustment but is thier a way i have to have it set so the computer dosent have to work so hard.
thanks
Old Sep 17, 2006 | 9:55 AM
shaight's Avatar
Default RE: what is up with the timing
The distributor on those engines are really a cam sensor and have to be set to 0° offset with a scanner thru the DLC port.
You can get it really close if not spot on by lining up the paint index marks applied @ the factory. Use a mirror and look at the
base of the dist. and intake at the back of the engine. There will be a white paint mark if you didn't clean it off during the repair.
Good Luck,Steve
jmms
HHR
Apr 17, 2015 4:22 AM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
mog703
Jul 26, 2006 2:34 PM
attmchappo
Jul 26, 2006 2:27 AM
sdelano
Oct 3, 2005 9:49 PM
