Wheels and doors
Old Sep 12, 2009 | 9:36 PM
SabrToothSqrl's Avatar
Default Wheels and doors
something is STILL rattling in my driver's door around the door lock. does anyone have the FSM or PDFs on the drivers door?!
also, what do I use to wax / polish the LTZ rims? They are not chrome, there just painted right? so normal car wax?
thanks guys!
Old Sep 13, 2009 | 8:55 AM
shawnvw's Avatar
Banned
<TABLE border=1 width="95%"><TBODY><TR><TH vAlign=bottom align=middle>Callout
</TH><TH vAlign=bottom align=middle>Component Name
</TH></TR><TR><TD vAlign=center colSpan=2>Preliminary Procedure
  1. Remove the door upper trim panel. Refer to Upper Extension Trim Panel Replacement.
  2. Remove the door window control switch. Refer to Door Lock and Side Window Switch Replacement - Driver Side and Door Lock and Side Window Switch Replacement - Passenger Side.
</TD></TR><TR><TD vAlign=center align=middle>1
</TD><TD vAlign=center>Front Side Door Locking Rod **** AssemblyProcedure
  1. Lower the window.
  2. Ensure the locking rod is in the unlocked position.
  3. Use a flat-bladed tool to disengage the detent tab and then remove the **** by pulling upward.
  4. When re-installing, push the **** down until the detent tab touches the locking rod opening cover.
  5. Push the detent tab in to lock the **** to the locking rod.
</TD></TR><TR><TD vAlign=center align=middle>2
</TD><TD vAlign=center>Front Side Door Trim Panel Cover
</TD></TR><TR><TD vAlign=center align=middle>3
</TD><TD vAlign=center>Front Side Door Trim Panel Cover Retainer (Qty: 3)
</TD></TR><TR><TD vAlign=center align=middle>4
</TD><TD vAlign=center>Front Side Door Inside Handle Bezel Cover
</TD></TR><TR><TD vAlign=center align=middle>5
</TD><TD vAlign=center>Front Side Door Trim Panel Bolt (Qty: 3)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
9 N·m (18 lb in)
</TD></TR><TR><TD vAlign=center align=middle>6
</TD><TD vAlign=center>Front Side Door Trim Panel AssemblyProcedure
  1. Disconnect the electrical connectors.
  2. There are 2 hooks located on the lower portion of the door trim panel that are being used for manufacturing installation ONLY.
  3. If these hooks are damaged during either removal or installation of the door trim panel, replacement of the panel is not required.
  4. When installing the trim panel start at the lock ****, pushing down and outward moving toward the upper front.
</TD></TR><TR><TD vAlign=center align=middle>7
</TD><TD vAlign=center>Front Side Door Cable RetainerProcedure
  1. Depress both tabs to remove cable and pull cable rearward out of handle assembly.
  2. When reinstalling cable make sure that it is fully seated past the guide tab.
</TD></TR><TR><TD vAlign=center align=middle>8
</TD><TD vAlign=center>Front Side Door Trim Panel Retainer (Qty: 12)
</TD></TR></TBODY></TABLE>
Old Sep 15, 2009 | 9:49 AM
Default wow
those are some big images! thanks!
what's the name of the software that you pull that stuff from?
Old Sep 15, 2009 | 9:52 PM
The wheels are clear-coated and should be treated just like the painted body parts.
Old Sep 16, 2009 | 7:44 AM
Default ok
thats what I thought, I will wax them tonight. I waxed the whole truck w/turtle wax caranbu (I can't spell) stuff... its so SMMMMOOOTHHH and water just rolls off of it!
Old Sep 16, 2009 | 6:33 PM
shawnvw's Avatar
Banned
those pics, and most of the pics I post are taken directly from GM;s service info website.
I can post them here by simply copy\pasting them directly from their webpage, and they usually end up that size.
If I want them smaller, I have to download, resize, upload to photobucket, then post links to them....copy\paste is way
easier and gives you more detail
Old Sep 17, 2009 | 7:36 AM
Default pictures
no,no, i wasn't complaining, I love large photos!
how does someone like me get access to that site?
Old Sep 17, 2009 | 3:17 PM
shawnvw's Avatar
Banned
Become a general motors service employee
Old Sep 17, 2009 | 3:23 PM
myotherchevyisablazer's Avatar
hey shawn,do you happen to wheel a ford bronco .....?
red
Old Sep 18, 2009 | 11:44 AM
Default employee
so its all through a web site? they dont make PDF ones anymore?
