Wheels and doors
something is STILL rattling in my driver's door around the door lock. does anyone have the FSM or PDFs on the drivers door?!
also, what do I use to wax / polish the LTZ rims? They are not chrome, there just painted right? so normal car wax?
thanks guys!
thanks guys!
<TABLE border=1 width="95%"><TBODY><TR><TH vAlign=bottom align=middle>Callout
</TH><TH vAlign=bottom align=middle>Component Name
</TH></TR><TR><TD vAlign=center colSpan=2>Preliminary Procedure
</TD><TD vAlign=center>Front Side Door Locking Rod **** AssemblyProcedure
</TD><TD vAlign=center>Front Side Door Trim Panel Cover
</TD></TR><TR><TD vAlign=center align=middle>3
</TD><TD vAlign=center>Front Side Door Trim Panel Cover Retainer (Qty: 3)
</TD></TR><TR><TD vAlign=center align=middle>4
</TD><TD vAlign=center>Front Side Door Inside Handle Bezel Cover
</TD></TR><TR><TD vAlign=center align=middle>5
</TD><TD vAlign=center>Front Side Door Trim Panel Bolt (Qty: 3)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
9 N·m (18 lb in)
</TD></TR><TR><TD vAlign=center align=middle>6
</TD><TD vAlign=center>Front Side Door Trim Panel AssemblyProcedure
</TD><TD vAlign=center>Front Side Door Cable RetainerProcedure
</TD><TD vAlign=center>Front Side Door Trim Panel Retainer (Qty: 12)
</TD></TR></TBODY></TABLE>
- Remove the door upper trim panel. Refer to Upper Extension Trim Panel Replacement.
- Remove the door window control switch. Refer to Door Lock and Side Window Switch Replacement - Driver Side and Door Lock and Side Window Switch Replacement - Passenger Side.
- Lower the window.
- Ensure the locking rod is in the unlocked position.
- Use a flat-bladed tool to disengage the detent tab and then remove the **** by pulling upward.
- When re-installing, push the **** down until the detent tab touches the locking rod opening cover.
- Push the detent tab in to lock the **** to the locking rod.
Tighten
9 N·m (18 lb in)
- Disconnect the electrical connectors.
- There are 2 hooks located on the lower portion of the door trim panel that are being used for manufacturing installation ONLY.
- If these hooks are damaged during either removal or installation of the door trim panel, replacement of the panel is not required.
- When installing the trim panel start at the lock ****, pushing down and outward moving toward the upper front.
- Depress both tabs to remove cable and pull cable rearward out of handle assembly.
- When reinstalling cable make sure that it is fully seated past the guide tab.
those pics, and most of the pics I post are taken directly from GM;s service info website.
I can post them here by simply copy\pasting them directly from their webpage, and they usually end up that size.
If I want them smaller, I have to download, resize, upload to photobucket, then post links to them....copy\paste is way
easier and gives you more detail
