Where to run amp power wire?
Hello, I have a 2007 Tahoe and I need to know the best spot to run my power wire throught the firewall. Any help would be appreciated. I would like to run it on the passenger side, as that is where the battery is.
Thanks in advance!!
Thanks in advance!!
RE: Where to run amp power wire?
I own a 97 Tahoe Ls and I drilled for a 4AWG wire through driver side. Just make sure you put a rubber grommet(Same size as whole) to protect from leaks and Rubbing on Bare metal.
Good Luck
Good Luck
You can run it to the driver side along the back of the engine compartment and through the factory grommet the body harness goes through. No drilling required.
barnesam
December 31st, 2022 2:34 PM
mattcotools
19
July 13th, 2011 9:35 AM
Vanshmack
November 25th, 2007 12:26 AM
