Where to run amp power wire?
Old Mar 2, 2008 | 5:41 PM
Craven Moorehead's Avatar
Default Where to run amp power wire?
Hello, I have a 2007 Tahoe and I need to know the best spot to run my power wire throught the firewall. Any help would be appreciated. I would like to run it on the passenger side, as that is where the battery is.
Thanks in advance!!
Old Mar 10, 2008 | 8:32 AM
nismorat's Avatar
Default RE: Where to run amp power wire?
I own a 97 Tahoe Ls and I drilled for a 4AWG wire through driver side. Just make sure you put a rubber grommet(Same size as whole) to protect from leaks and Rubbing on Bare metal.
Good Luck
Old Mar 10, 2008 | 9:08 PM
Welcome to the Tahoe forum. Thanks for your help.
Old Mar 11, 2008 | 12:19 AM
bs07hoe's Avatar
You can run it to the driver side along the back of the engine compartment and through the factory grommet the body harness goes through. No drilling required.
Old Mar 11, 2008 | 9:30 PM
Old Mar 13, 2008 | 2:16 AM
bs07hoe's Avatar
oh ive been lurking a long while and just realized this was my first post. Good times!
barnesam
Dec 31, 2022 2:34 PM
Lymsleia
Sep 11, 2011 9:40 PM
mattcotools
19
Jul 13, 2011 9:35 AM
Vanshmack
Nov 25, 2007 12:26 AM
ralphtrent
Jan 5, 2007 12:17 PM
