Wierd problem with turn signals and radio... 07 Tahoe
Old Feb 18, 2011 | 9:01 PM
  #31
Site wouldn't work for me.
Got this message:
E4214: WARNING: You have received this message for one of the following reasons:
1. Session has timed out.
2. Another user is using the same user id/password and has terminated your session.
3. Security violation - user does not have access to this application.
Old Feb 18, 2011 | 11:05 PM
  #32
@ 73shark, I tried the link I posted on different computer and it worked, may want to try clearing your cashe, as I don't have any special log-in.
Old Feb 18, 2011 | 11:21 PM
  #33
Ahhh I see why you got that shark, don't click on the sps info tab, just stay on the main TIS page and enter your VIN in the first box
Old Feb 19, 2011 | 12:20 AM
  #34
That's what I did but I either entered the VIN wrong or it didn't like lower case. Works now. Thanks.
Old Feb 19, 2011 | 9:19 AM
  #35
QUETRANPA's Avatar
well guess what!!!
I unplugged the battery last night for about 5 min, and when I plugged it back the radio worked just fine!!! I guess the system needed to be reset or something
one thing I noticed is that no one with this problem has posted what they did to fix the problem in their vehicle
I'm still going to get the battery rundown software upgrade that shark mentioned, and look up my vin # in that website that in2pro posted and see what comes out of it
so thank you guys for your help and now on to the next project!!!
Old Feb 19, 2011 | 12:11 PM
  #36
The only thing we're lacking is the Microsoft automatic updates and the BSOD.
Old Feb 25, 2011 | 12:08 PM
  #37
Official GM Rep
QUETRANPA, glad to see that you were able to fix this issue. If you have any other issues or questions about your vehicle feel free to contact me. Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Old Jan 11, 2012 | 9:34 AM
  #38
nvrflw's Avatar
I am having problems similar to what Quetranpa was having. I installed my GM nav myself in my 08 Silverado and its worked great for about a month until recently. A few days ago I turned my truck on and it boots up fine, but it goes straight into "Off" mode, blue screen with clock in middle, and is frozen there. None of the buttons work. I pulled the fuse for a few minutes and put it back in and that worked so I was happy. A few days after that it happened again so I pulled the fuse once again, let it sit, then put it back in and it turned on blank again. I hit the eject button to eject my mp3 cd and it spit the cd out and then turned right on. This morning once again it turns on frozen. I do the fuse and nothing happens, try to eject the cd and nothing happens, pulled the fuse again and left it out for my 1hr commute to work and still nothing. I am now at a loss. Any suggestions?
Old Jan 11, 2012 | 6:42 PM
  #39
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Have you taken the vehicle in for an inspection for this issue? Did you purchase the system from the dealer? Have you considered a faulty unit?
I would recommend taking it in for an inspection.
Keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Jan 12, 2012 | 10:07 AM
  #40
nvrflw's Avatar
I bought it from a friend of a friend and the guy that I bought it from works at a dealership so he was able to install and unlock it for me. About a month and a half later is when I started having problems. I took my truck into the dealership yesterday and they pulled my CD out and tried to reprogram it but still came up frozen. They told me that the unit is supposed to go in a 2010-2012 vehicle which is why it may be freezing up. I'm almost positive that that is irrelevant, but whatever the issue is I took it out last night and put the factory radio back in
