Wind noise at 65+ mph possibly due to recirculate vent issue
Old May 25, 2012 | 12:28 PM
Typerod's Avatar
15 Year Member
Default Wind noise at 65+ mph possibly due to recirculate vent issue
Hi all, has anyone had an issue where there is a lot of wind noise coming from the right side of the dash board? I think it has something to do with the recirculate vent. It happens at speed of 65 mph or more, its a consistent wind noise. I can make it change when i hit the recirc button, it'll get quiet for a few secs then get noisy again. It does the same exact thing when I turn off recirculate, quiets down then gets noisy again. Maybe the recirc vent (im sure im not using the proper term) is stuck in an off position and catching the incoming wind from below the windshield. Hopefully it wont be too expensive to repair. Thanks for any info!
edit: Just realized after Louis' request for part of my VIN that I failed to mention its a pre 2007 Tahoe LTZ 4x4.
Old May 25, 2012 | 1:47 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Typerod,
Would you please PM me the last 8-digits of your VIN, so I can look into this further for you?
Louis
GM Customer Service
Old May 25, 2012 | 3:48 PM
Typerod's Avatar
15 Year Member
Louis, just sent you the info you requested thru PM. Thanks so much!
Old Nov 14, 2013 | 7:31 AM
gilbert9's Avatar
2013 Tahoe, wind noise on passenger side. Adjusting the door the fix or not?
Old Nov 14, 2013 | 7:33 AM
gilbert9's Avatar
correction, 2013 Tahoe wind noise on driver side.
Old Nov 16, 2013 | 3:51 PM
Typerod's Avatar
15 Year Member
My issue went away on its own. But it did have something to do with the recirculate vent. When I put recirc mode on, thats when the noise happened, but when I turned it off, noise is gone. Mine had nothing to do with door adjustments.
Old Apr 12, 2015 | 11:06 AM
TBONE 21's Avatar
I have the same issue on my 2013 suburban. Has anyone come up with a fix yet or could you tell me where the intake is where the recirculator valve is
Old Feb 12, 2023 | 4:52 PM
Noah ziska's Avatar
Has anyone solved this problem? My noise comes from the drivers side.
2011 suburban
JoseC
Feb 27, 2012 7:14 PM
c4tag
Feb 6, 2012 5:35 PM
goatdriver
Jan 18, 2012 9:03 PM
dgriffith
Nov 29, 2011 1:35 PM
cutekel1985
Nov 15, 2011 8:39 AM
