Window switch question
Old Jul 27, 2023 | 10:34 PM
Kintla's Avatar
Default Window switch question
My right front window switch was not working, the switch sent current to bring it up but wouldn't send current to the motor to bring it down. The lock/unlock button worked.
I swapped it out with a new switch from the dealer and the window switch worked great but the door lock button wouldn't work. I returned the switch.
I just put in a new aftermarket switch, same problem. Window works, but the door lock doesn't.
What's going on here?
Any thoughts?
It's on 08 suburban 2500 LS
Old Jul 27, 2023 | 10:38 PM
Rednucleus's Avatar
It may be a problem with the driver's door switch affecting passenger side function.
Old Jul 27, 2023 | 11:24 PM
Kintla's Avatar
Thought about that, but the lock works with the original switch but doesn't work with the new switch.
I think it's a problem with the new switch, like 2500 suburbans have different wiring than 1500 or something. The dealer had a hard time tracking down the right switch for it.
Volts gets through to the lock actuator on the old switch but no juice gets through the new switch.
I'm stumped.
Old Jul 28, 2023 | 8:14 AM
Tapuaeleele's Avatar
I'm stumped.
IF You're near a junk yard perhaps you could take it apart and parts to see what works
Old Jul 28, 2023 | 11:19 AM
Kintla's Avatar
It's just circuit boards
Old Jul 28, 2023 | 11:20 AM
Kintla's Avatar
Does anyone know if there's programming thing with replacing door lock switches on Suburbans?
Old Jul 28, 2023 | 12:54 PM
Rednucleus's Avatar
I have cleaned contacts in failing switches and re-soldered contacts on circuit boards to keep them going
Old Jul 28, 2023 | 4:55 PM
Kintla's Avatar
I tried cleaning the contacts twice, it didn't bring it back. Soldering circuit boards is above my pay grade.
Old Jul 31, 2023 | 2:00 PM
Kintla's Avatar
Apparently this part does require programming for vehicle to recognize it. Dealer wants $170 to do it.
Any recommendations on a reader that will program as well?
Desp
Oct 3, 2016 7:06 AM
pkupman_77
Aug 22, 2015 2:50 PM
Ryan Brickel
May 13, 2012 8:34 AM
kylemason
Nov 21, 2010 10:11 AM
NJGTP
Oct 3, 2005 9:52 PM
