windshield wiper problem.
Old Jan 29, 2008 | 4:53 PM
sm3earl's Avatar
Default windshield wiper problem.
I know this isnt the right area but I know there are lots of really smart people on here and they dont look at other areas.
My problem: I bought a 98 lumina a while back and today only the driver wiper worked and then 5 min later, neither one works.
Could the arm broken a tooth off the moter or skipped something? I can hear the moter, the arms try to move, but dont.
Any help or suggestions would be awesome.
-Shawn
Old Jan 29, 2008 | 5:41 PM
Slammed's Avatar
Default RE: windshield wiper problem.
I would check the plastic bushings that connect the wiper arms together to the transmission (wiper assembly) all you have to do is open the hood remove the wipers and then the cowl and you should be able to get in there to check things out
Old Jan 29, 2008 | 5:42 PM
sm3earl's Avatar
Alright, thanks, ill try that a little later.
Old Jan 30, 2008 | 10:33 AM
sm3earl's Avatar
Anyone else have any ideas of what went wrong?
Thanks for any suggestions or advice.
Old Jan 30, 2008 | 4:00 PM
Slammed's Avatar
ok so the bushings are intact and all arms move together??? then replace the arm that moves alone cause its stripped
Old Jan 30, 2008 | 4:36 PM
ZX1100F1's Avatar
Have the wipers recently been operated when snow or ice has blocked them from moving?
Have you tried to assist the wipers by hand when they are switched ON? Will they then wipe?
Is the motor just humming or is it actually rotating?
jwjj
Apr 18, 2008 10:43 PM
sm3earl
Feb 17, 2008 8:20 PM
sm3earl
Feb 16, 2008 3:58 PM
blantz
Feb 16, 2008 3:52 PM
