Won't crank
Old Dec 27, 2010 | 11:17 AM
patmaguire's Avatar
Default Won't crank
Hello friends, the burban on a rainy day shut down at about 25mph, turned over but would not start, pushed it the last 1/2 mile home, tried to start, turned over, battery went dead, replaced the battery with a new one, dash lights up, wont crank, tested starter, passed, replaced starter, dash lights up and starter engages but wont turn over. what do i check now? thank you
Old Dec 27, 2010 | 12:20 PM
jvtahoe's Avatar
Bad fuel pump or filter?
Is the air intake box clean and dry?
Old Dec 27, 2010 | 1:08 PM
patmaguire's Avatar
I found a fuel leak, its behind and under the alternator and its a big leak, i think this is my original problem that cause the burban to stop running, but this doesnt explain why it will now not turn over, any advice on the fule leak is welcomed, hard to see exactly where its coming from cause its a big leak and the alternator is blocking my view
Old Dec 27, 2010 | 9:10 PM
Welcome to the forum.
Could be hydro-locked. IOW one or more cylinders are full of gas or water if a bad head gasket.
spiderpig773
Dec 30, 2012 10:23 AM
Shanedmoore
Jan 24, 2009 1:26 PM
buddy@exxon
Jan 9, 2009 5:19 PM
calbers
Jan 22, 2008 5:06 PM
Lunchbox
K5 Blazer
Nov 25, 2006 1:14 AM
