wont start when cold
Old Dec 4, 2014 | 11:03 AM
Rvaburb's Avatar
Default wont start when cold
04 1500 burb (wont start when air temp is cold) once it starts it will keep starting though!
I have noticed that when the temp gets down under 40deg that the truck will not start without stepping on the gas pedal (all the way to the floor). I am having issues with the flex fuel sensor but do not think that is the issue. I sure could use some help on this one!! motor is tuned up new plugs less the 20k , k&n filter , oil changed every 3k newer fuel filter 20k on it. all in all I take care of her very well. I have a huntch that it could be fuel pump??? please advise.
happens if there is a full tank our less than 1/4.
Old Dec 5, 2014 | 2:11 PM
2000suburbanjeff's Avatar
best way know get fuel pressure tester.test your psi and then go from there.does sound like a pump tho
fmxrider7
Apr 29, 2014 2:42 PM
tracerbullet
Dec 6, 2012 2:49 PM
papermill125
Sep 6, 2008 3:53 AM
papermill125
Sep 3, 2008 5:55 PM
ems_mike85
Jan 3, 2008 8:07 AM
