Worst noise Ever!!! Help!!!
Old Feb 1, 2007 | 8:53 PM
96on24s's Avatar
Default Worst noise Ever!!! Help!!!
96 Tahoe 4wd and its FUBAR. A noise started coming out if the rear end and progressively got worse until one sunny day when a huge plunk came from the rear. Now at a low speed, once the truck rolls to a certain point there is a metal plunk and it is really loud. reminds me of a locker on a 4 wheel turning with acceleration. is this the rear diff, axle, transfer case??? it is not drivable at all
Old Feb 2, 2007 | 8:17 PM
Default RE: Worst noise Ever!!! Help!!!
Welcome to the forum.
Does the noise occur once per wheel revolution (probably differential problem, e.g. broken ring gear tooth) or once per driveshaft revolution (probably U-joint problem)?
Old Feb 3, 2007 | 12:59 AM
Fiesty96's Avatar
I agree with 73shark and would add worn sleeve yoke and/or mainshaft spline. Chevy U-joints are infamous for breaking (or at least that's been my experience)
Old Feb 3, 2007 | 3:17 AM
96on24s's Avatar
it does occur once every revolution, and it just so happens that this problem came after i put 24" worth of rim on it. would the weight of the rims have anything to do with this? 305/35r24 Kumhos @ 45lbs ea. and 40-50#wheel, here is a couple of pics
http://img182.imageshack.us/img182/2010/dsc01171ma9.jpg
http://img245.imageshack.us/img245/407/grad1023uq6.jpg
Old Feb 3, 2007 | 3:24 AM
Every revolution of what? Driveshaft or wheel?
Old Feb 3, 2007 | 3:28 AM
96on24s's Avatar
wheel, rear driver left
Old Feb 3, 2007 | 2:38 PM
Not sure how the '96 Tahoe parking brake is set up but if it uses a shoe system inside the rotor hat, then it could be something as simple as a broken spring. Another possibility if it's just the driver side is a bad bearing. Otherwise look in the differential.[:'(]
Old Feb 3, 2007 | 5:03 PM
96on24s's Avatar
that helps me alot and i appreciate it, this is my secondary car (project car) so i have not driven it since july of last year and now that i think about it i just replaced the rear shoes that same week. So i feel like i know where to take a look at this truck so i can get her ready for the spring, thanks alot. It must be a bearing, or that rear diff so i will keep you posted when i get it on a lift next week
Old Feb 3, 2007 | 6:43 PM
Since you just did the rear brakes, I would check to make sure a spring didn't break or come loose before I went too deep into the mechanicals.
austonwerner4
Camaro
May 21, 2012 10:51 AM
Tileman
12
Jun 29, 2007 4:02 AM
