Yukon Denali Air Suspension
Old Nov 12, 2011 | 5:35 PM
PG2676's Avatar
Default Yukon Denali Air Suspension
Is it normal for the rear suspension air compressor to run for about a minute after the vehicle starts? Does it only kick in if air has bled from the system while parked? How can I tell if the system is leaking?
Old Nov 12, 2011 | 6:37 PM
My will run sometimes on startup if I've changed the load after it was shut down. A minute sounds excessive.
Old Nov 16, 2011 | 12:48 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I am sorry to hear about your frustration with your air suspension. I would like to do some research on your problem. Could you please pm your name and VIN number so I can assist you further?
Louis
GM Customer Service
Old Nov 16, 2011 | 7:51 PM
PG2676's Avatar
Louis
GM Customer Service
Not a chance.
Old Nov 17, 2011 | 8:59 AM
SabrToothSqrl's Avatar
Default lol
Ca-Caw...welcome to wal-mart...ca-Caw
I mean "see your dealer"
Ca-Caw! (think parrot)
A minute does seem long. Mine will run at start up usually a max of 10-20 seconds.
If I hook my boat to it, it will run longer, but never 60 seconds.
If you have no errors / warnings...
Does it only run at start up?
Does it ever run driving or after?
I would think a slow leak would cause it to run more than normal, but not enough to actually break the compressor...
I haven't layed under my Tahoe yet since it's under warranty, but you could cover the bags with soapy water (paint brush) then put key in 'run' (you shouldn't have to start it).
then look for bubbles w/a flash light.
Old Nov 17, 2011 | 9:18 PM
Simple Green is a good leak detector. Just spray it on and a leak will look like the head on a cold draft.
Old Nov 18, 2011 | 8:30 AM
PG2676's Avatar
Right! I should recognize that. Thanks guys.
Old Nov 18, 2011 | 8:44 AM
Default simple green
my favorite cleaner! i use it everywhere!
BlackDenali
Jan 9, 2011 7:55 PM
biglg
Mar 26, 2008 4:04 PM
tahoe07
Dec 23, 2007 9:55 PM
dustyswinger
Oct 29, 2007 11:20 PM
07summitwhite
May 11, 2007 8:35 PM
