2001 suburban power seat issues
Old Nov 25, 2020 | 10:21 AM
Brian Hiltscher's Avatar
Default 2001 suburban power seat issues
Hi all, I am new to this forum, so if there is a thread associated with the issue I am having, please forgive and point me to that thread.
The issue I am having is with the driver's side power seat, it is not functioning at all. The passenger side power seat is working, however (I believe both use the same circuit/fuse, correct?). I bought a new switch for the power seat, and that did not fix the problem. Any suggestions on how to diagnose what is wrong would be most appreciated. I am told that there are 2 motors, one for the seat bottom, and another for the seat back. Since neither works, I suspect that it isn't a motor problem.
Thanks in advance for any help with this!!
Old Nov 26, 2020 | 7:21 AM
I have diagnosed this problem a bit further. I was able to "hotwire" the seat motor via a direct connection from the battery, and move the seat back and forth. So the problem definitely does not lie with the motor. I am now assuming that the problem is associated with the seat control box, which is a small plastic box underneath the drivers seat with a circuit card inside.
Does anyone have experience with a bad power seat control module/box?
Old Nov 26, 2020 | 2:05 PM
I would unplug the seat harness and see if it's getting any power.
nelson123
Dec 19, 2014 9:29 AM
cahubbs
Oct 1, 2014 6:45 AM
Austinleek
Dec 12, 2013 1:12 PM
pops1981
Oct 8, 2008 5:49 PM
Gman
Jan 1, 2008 2:17 AM
