Tracker 1989-2004
Platform: CAMI (Suzuki)
01 Tracker LT Rear Axial Bearing Retainer & ABS Reluctor Ring
Old May 27, 2014 | 3:46 PM
cjfelsinger's Avatar
Question 01 Tracker LT Rear Axial Bearing Retainer & ABS Reluctor Ring
I needed to change the Rear wheel(axial) Bearing, in which the Bearing
Retainer(Collar) / & ABS Reluctor Ring had to come off first - Normal.
I have new Retainer & ABS Reluctor Ring from Dealer.
Question: Is the Reluctor Ring supposed to be 0.0030"ID larger than the
retainer(collar) that it's supposed to be press fit onto.
I got the parts from the Chevy Dealer by Ref. the VIN#. The parts manager & I talked to the lead Mechanic who looked in the Dealer service manual and found no answers as to the size difference.
The only this that thing that I can see as a possibility is that the Axial Shaft is 0.0025"OD larger than the Retainer ID that press fits onto it, and then the reluctor ring would ? then be tight on the retainer once it's all assembled?
Has anyone else changed a rear axial Bearing with rear ABS and gone though this?
Joeseph
10
Jan 4, 2022 10:23 AM
Dustinfox
Sep 4, 2015 2:38 PM
Chevygirl4x4
Jan 17, 2014 6:30 AM
danlsmith
Feb 20, 2009 1:21 PM
jcook
Feb 25, 2007 6:55 AM
