Tracker 1989-2004
Platform: CAMI (Suzuki)
02 Tracker shakes when first accelerating
Old Mar 17, 2013 | 2:03 PM
katgirl46's Avatar
Question 02 Tracker shakes when first accelerating
When you first start going it shakes...but once you go a little faster its smooth..any ideas?
Old Mar 17, 2013 | 8:58 PM
tymr287's Avatar
What is exactly shaking? The steering wheel? Do you feel it in the seat? Or is it just everything is shaking?
Old Mar 18, 2013 | 6:00 AM
Jeff Collision's Avatar
Inspect the spark plugs, spark plug wires and vacuum hoses. Look for spark plugs that are covered in oil or sediment or damaged, spark plug wires that have damaged insulation, and vacuum hoses that are unplugged or leaking. Check the fuel pressure with gauge. While most acceleration problems are likely caused by problems with the plugs, wires or fuel, a variety of sensors and other components can cause similar problems. Diagnostic code readers can be used to locate faulty sensors and other electronic devices.
Old Mar 19, 2013 | 8:39 AM
katgirl46's Avatar
ok we found the problem, the u-joints were junk and one of them was unbalanced, now smooth as butter. thanks yall!!
TheTowingCowboy
Aug 8, 2011 9:27 PM
dtipainter
Nov 2, 2007 10:46 AM
sethlives1
Cobalt
Oct 7, 2007 7:39 PM
coling659
Apr 29, 2007 9:55 PM
birmingham
Mar 4, 2007 5:29 PM
