Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 Tracker 4wd not working
Old May 4, 2020 | 7:10 PM
Tincup19's Avatar
Default 2000 Tracker 4wd not working
Hi, when I shift my tracker into 4wd the light on the dash doesn’t light up and the front drive shaft doesn’t spin. Please help!
Old May 5, 2020 | 6:16 AM
L84sky's Avatar
Is your air pump working?
https://chevroletforum.com/forum/tra...problem-99718/
Old May 5, 2020 | 7:21 AM
Tincup19's Avatar
Originally Posted by L84sky
Yes, well when i turn the key on the pump runs for about 10 seconds then stops. Initially the light was blinking, I saw some people had luck taking the pump apart and cleaning it and replacing the o-rings. So i did that and initially the light was blinking for a couple seconds now it doesn't blink at all.
Old May 5, 2020 | 7:50 AM
L84sky's Avatar
You have an air leak. In a sealed system the pump will not run more than 3 seconds.
The PCM cuts power to the pump after 10 seconds to protect the motor.
Remove the end of the hose that connects to the bottom of the front differential and plug
it with a Phillips screwdriver. It the motor still runs for 10 seconds you have a bad air pump
or a leak in the air line. If the motor stops after 2 or 3 seconds you have a bad differential.
Old May 5, 2020 | 3:46 PM
Tincup19's Avatar
do i pinch off the end of the hose going into the differential prior to shifting it into 4wd or after i've shifted it and once the pump has engaged?
Old May 5, 2020 | 4:10 PM
L84sky's Avatar
Turn the car off. Pry the hose off the differential. Plug the hose with something. Turn the ignition ON. Move the transfer case lever to 4WD-high. You should hear the pump run for 3 seconds and quit. When it quits the 4WD indicator on the dash should illuminate. If all that happens the pump system is good to the differential. If instead the pump runs for 10 seconds and quits you have a leak before the differential. In that case you will most likely need to repair or replace your pump.
Old May 5, 2020 | 8:42 PM
Tincup19's Avatar
So doing what you said, the pump went off after a couple seconds and the 4wd light came on. So basically that means the actuator inside the differential is shot correct?....
Old May 5, 2020 | 9:07 PM
L84sky's Avatar
It sure looks like it.
The actuator is over $200 but the good news they are still available. The bad news is the differential needs to be removed from the car to replace the actuator.
Before I pulled the differential I would connect a bicycle pump and a pressure gauge to the nipple where you pulled off the air hose for testing.
Try to pump the actuator up to 6 PSI. If it will not hold pressure you will have to pull the front diff to find the leak.
Old May 5, 2020 | 9:15 PM
Tincup19's Avatar
Ok so this vehicle was given to me last fall to basically get running and just take out in the woods. I had to swap out the transfer case and a few other things to get it running. Since its something to just screw around with and take the kids out in the woods, would it make more sense to just weld the actuator in the engaged position and install locking hubs?
Old May 6, 2020 | 5:52 AM
L84sky's Avatar
Here is a link to do just that:
https://www.diymetalfabrication.com/...-actuator-fix/
