Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 Chevy Tracker 4x4 actuator
Old Jan 4, 2025 | 10:01 PM
Drewnewsome's Avatar
Default 2001 Chevy Tracker 4x4 actuator
Does anyone know where to get a replacement?
Old Jan 5, 2025 | 7:24 AM
L84sky's Avatar
Try searching on these part numbers.
Old Jan 5, 2025 | 6:04 PM
Turns out it’s not the pump pretty sure my diff isn’t sliding with the lever going to get it on lift and take a look at that
Old Jan 5, 2025 | 6:49 PM
L84sky's Avatar
If it's not the pump it's likely a ruptured diaphragm inside the front diff.
Old Jan 5, 2025 | 6:52 PM
Awesome thank you
Old Jan 5, 2025 | 7:30 PM
L84sky's Avatar
If you can blow air into the diff with your mouth the diaphragm is shot.
Old Jan 23, 2025 | 10:08 AM
Default Got the 4WD working but new issue
I got the 4WD working it was the disc, pulled one from another we had and it works fine. New issue is it starts for little bit then dies or will run then when at idle or coasting down hill will die and battery light will go on. I changed the battery and it’s fully charged, I was wondering if it would be the alternator or something else?
Old Jan 23, 2025 | 11:26 AM
L84sky's Avatar
Measure the battery voltage with the engine off.
The battery voltage should be about 2 volts higher with the engine running if the alternator is working correctly.
The battery light will always illuminate if the engine is not turning.
Old Jan 25, 2025 | 11:12 AM
Alternator is fine, we’ve narrowed it down to either the cam sensor or the fuel regulator going to pull a cam sensor off of one we have and see if it does the trick, leaning more toward cam sensor because last time it ran it would idle high then lower then back up continuously
Old Jan 25, 2025 | 2:29 PM
L84sky's Avatar
Is this the four cylinder or the V6?
