Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 Tracker won't fire
Old Nov 30, 2013 | 3:36 PM
MooseMayhem's Avatar
Default 2001 Tracker won't fire
So I have 2001 Chevy tracker. I replaced the timing chain and the whole nine yards. Put it all back together and it turns over with no fire. Ended up getting a p0340 error. Replaced the crank shift sensor and the cam shaft sensor. Once that was done, turned the key and the car started. Ran for about 30 seconds before I opened up the accelerator and it died. Now it's back to not firing. Getting it to turn over but no fire. Getting a cam shaft sensor error again. Ideas?
Old Dec 1, 2013 | 7:10 AM
It is possible that when timing chain was replaced it was not set correctly. Therefore the timing is a bit off.
Old Dec 1, 2013 | 9:48 AM
Any other thoughts on what it might be? I was thinking maybe a short in the wiring harness?
SDFoster22
Dec 16, 2013 6:15 PM
roscowgo
Jan 27, 2010 2:52 PM
PrecisionAuto
Nov 24, 2008 11:42 AM
bluezmom
May 24, 2008 8:51 AM
boltonranger
May 20, 2006 12:05 AM
