Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 chevy tracker LH rear brake adjuster and pawl
Old Apr 21, 2025 | 5:41 PM
Jeff_89's Avatar
Default 2002 chevy tracker LH rear brake adjuster and pawl
Hey everyone, Im wonderin if someone can help me out. I got a 2002 chevy tracker zr2 v6 4x4. Im looking to find a suzuki number or any sort of reference for the driver rear brake adjuster and pawl.
I have searched and called everywhere and I cant find anything lol. If you can help out in any way it would really help. Thanks a ton!!
Old Apr 21, 2025 | 8:26 PM
L84sky's Avatar
There are two styles of brake hardware for the Tracker. My 2001 Tracker has the old (and hard to find) style. Your 2002 may have the newer style. Check out this link to see the difference between old and new.
https://chevroletforum.com/forum/tra...juster-113981/
Old Apr 21, 2025 | 8:33 PM
Jeff_89's Avatar
mine also has the old style adjuster. And everywhere I call says they're pretty much impossible to come by, and I believe it. I've read that there are suzuki parts that interchange with these. Is that true?
Old Apr 22, 2025 | 8:53 AM
L84sky's Avatar
All Tracker parts are made by Suzuki. Suzuki parts can be ordered from Megazip.net or PartSouq.com. Unfortunately I have been unable to find parts numbers for the older style brakes on either site.
I did see the older style adjuster on ebay: https://www.ebay.com/itm/40519680822...3ABFBMooT92stl
Old Apr 24, 2025 | 7:39 PM
Tom999z's Avatar
You may have to look in a junkyard. My local junkyard has four Trackers 😀
Old Apr 28, 2025 | 5:31 PM
Jeff_89's Avatar
I'm pretty sure I found the correct adjuster for mine. I found it on ebay and like I've read throughout and everyone else says, it is a suzuki part number. I dont get why gm decided it was smart to discontinue something for the brakes lol. But I can give you the part number for the one I found that best matches my 2002 tracker, Im not sure what year your tracker is. The adjuster I found is for an 06-08 grand vitara. The adjusters for the earlier model vitaras do not match mine haha
Old Apr 29, 2025 | 5:06 AM
L84sky's Avatar
Chevy discontinued support for the Tracker when Suzuki filed for bankruptcy.
My Tracker uses the early style adjuster.
Old Jun 11, 2025 | 2:43 PM
-Nate's Avatar
Question Rear Brake Adjusters
So ;
What causes them to wear out then ? .
The park brake on my 2000 Tracker comes up WAY too far so I'm sure I'll need to go in there ere long .
Luckily there are plenty of low mileage later model Grand Vitaras in local scrapyards .
Diana2009
Nov 28, 2024 6:39 AM
Johnskowfoe
Aug 17, 2023 12:53 AM
sjane1026
May 13, 2021 7:06 PM
kozmic_tulip
Feb 10, 2020 5:28 PM
MaDe iN Poland
Jul 27, 2013 9:03 AM
