Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 Tracker code P0103
Old Aug 19, 2023 | 4:13 PM
salvizar562's Avatar
Default 2002 Tracker code P0103
Hello. I am having trouble fixing my 2002 Tracker 2.5L. Got the service engine soon and the code P0103- Mass or Volume air flow A circuit high. Car was running rough, losing power, and would turn off when idling. I replaced the mass air flow sensor (MAF), but it did not seem to fix the problem. The issues still persist. Has anyone had this issue and would anyone know what the solution may be? I have been told it could possibly be the intake air temperature sensor, any suggestion is that might be correct?
Old Aug 19, 2023 | 6:13 PM
L84sky's Avatar
I'm not 100% sure on this but I think "MAF circuit high" indicates an open circuit. If replacing the MAF sensor did not fix the problem you may have a broken wire. This is part of the test procedure in the factory service manual:
Old Aug 19, 2023 | 6:30 PM
Oh I see. I not a mechanic, but I do work on my as much as possible. Would tool would I need to check the voltage?
Old Aug 19, 2023 | 6:39 PM
As L84sky posted, you need a DMM. (Digital Multi Meter)
Old Aug 19, 2023 | 6:42 PM
Just found it! Thank you very much. I will give it a try.
Old Aug 19, 2023 | 7:47 PM
L84sky's Avatar
I don't have prints for a 2002 but on my 2001 the MAF signal can be measured on PCM connector 2 Pin 23.
Old Mar 17, 2024 | 10:56 PM
Skudmissal's Avatar
MY 2002 is doing the exact same thing. Did you ever get this issue resolved?
Johnskowfoe
Aug 17, 2023 12:53 AM
sjane1026
May 13, 2021 7:06 PM
Michael Yu
May 3, 2021 7:52 AM
JimDoug
May 31, 2019 9:34 AM
MaDe iN Poland
Jul 27, 2013 9:03 AM
