Tracker 1989-2004
Platform: CAMI (Suzuki)
2004Tracker towing behind RV
Old May 8th, 2015, 11:08 PM
Teva's Avatar
Question 2004Tracker towing behind RV
Question: How do you tow a 4x4 2004 tracker behind a RV motorhome?
Old May 20th, 2015, 5:27 PM
jettyspicer's Avatar
Default Tracker Towing
The 4 wheel drive Tracker can be towed with all 4 wheels on the ground. It will require a base plate and a tow bar. (Blue Ox makes both). You put the key in the accessory position and the 4 wheel drive transfer shifter in nutural.
You will also need a brake light kit.
Jetty
Old May 27th, 2015, 5:32 PM
Teva's Avatar
Jetty
I have done all that But when I leave the car in park and put the transfer case in neutral the back tires locked up? what am I doing wrong???? Please advise. Thank you
Old May 28th, 2015, 7:47 AM
If you indeed have the transfer case in neutral, it would be impossible for the rear wheels to be engaged.
Try it without the Tracker being connected to your RV. With the engine running, put the Transfer case in neutral: Put the auto shifter in drive: Your Tracker should not be able to move if the Transfer case is truly in neural. If it does move, then I am lost.
I have been pulling my Tracker for several years and never had your problem.
Jetty
Old May 31st, 2015, 6:08 PM
Teva's Avatar
Smile
Jetty
Thank you very much I will try it before I take off next
Nyron
Silverado & Fullsize Pick-ups
June 28th, 2010 10:55 AM
racemalone
August 5th, 2009 7:23 PM
Rodehard
November 18th, 2008 8:44 PM
ahjah9
December 7th, 2006 10:20 PM
Quick Reply: 2004Tracker towing behind RV
