Tracker 1989-2004
Platform: CAMI (Suzuki)
2nd Gen Tracker Rear Disc Conversion
Old Aug 22, 2022 | 9:02 PM
sodafire's Avatar
Default 2nd Gen Tracker Rear Disc Conversion
Is there a kit someone sells or a homemade mismatched bolt on kit that i could put together? Ive had it with rear drums. PiA they are.
Old Aug 23, 2022 | 5:25 PM
sodafire's Avatar
For some reason the passenger side self adjusts to much. If i raise the rear off the ground and put it on jacknstands and run it, only the drivers side turns. I can force the paasenger side by hand but it stops instantly. I dont see the pawl inside that supposed to adjust it. Ive spun the adjuster in so the wheel would turn like it supposed to. But it keeps tightening up on it own and i dont see how.
Old Aug 24, 2022 | 1:42 AM
oilcanhenry's Avatar
Rear disks on a lightweight 4x4 are a waste, if you could find them. I had an AMC Jeep CJ-5 and never needed disks in the back and that Jeep weighs more than your Tracker does. Lots of half ton pickups don't use rear disks.
Old Aug 24, 2022 | 8:43 AM
sodafire's Avatar
I dont want discs because of better stopping power, i want them because ease of maintenance.
Old Aug 27, 2022 | 8:22 PM
I understand. I don't like all the springs either. And the star wheel doesn't always work right either,
MAPOT
Aug 4, 2022 4:35 PM
Trevor Brandt
Mar 8, 2021 4:56 AM
Darrin Kalk
Feb 13, 2020 9:03 AM
akjoe
Sep 2, 2015 7:08 PM
Chris_Harper
Dec 11, 2009 3:03 PM
