Tracker 1989-2004
Platform: CAMI (Suzuki)
4x4 conversion
Old May 4, 2026 | 6:45 AM
Rgbohot's Avatar
Default 4x4 conversion
Greetings everyone. I’m new to the forum just recently joining to get information and advice on converting my 2003 2WD Tracker 2-Dr, 2.0L automatic to 4WD. I’m down to the final steps on this project. All the mechanical parts are in and working but I’m having trouble sorting out the wiring for the 4WD indicator, transfer case switches and 4WD actuator pump. Does anyone have access to a transfer case wiring schematic for a 2003, 2.0L automatic? I have one for the 2000 and 2001 year models but those show different PCM pin connections which makes me think the 2003 is likely to be different also.
Old May 7, 2026 | 9:22 AM
Rgbohot's Avatar
If no transfer case wiring diagram is available, maybe someone has info on the correct PCM pin numbers tor the blk/org (4WD switch) wire and the org/wht (4WD Low switch) wire from the transfer case on a 2003 Tracker. Any help would be appreciated.
Old May 7, 2026 | 11:01 AM
L84sky's Avatar
You might have to pay $20 for year specific schematics.
Mitchell 1 DIY
Old May 7, 2026 | 3:23 PM
Rgbohot's Avatar
Mitchell 1 DIY
I did that in portal-diagnostic.com. They were the same price but did not have that particular schematic for the 2003 model. I’ll try the link you forwarded. Thanks!
trebreklaw
Jun 7, 2022 6:45 AM
rwolford
Oct 9, 2021 7:58 AM
SWHouston
Feb 23, 2013 2:33 PM
k2500
Jan 4, 2012 2:26 PM
snowed-in-chevy
Feb 13, 2010 4:57 AM
