Tracker 1989-2004
Platform: CAMI (Suzuki)
Can't connect to computer
Old Dec 11, 2022 | 6:54 PM
  #11
R Sadler's Avatar
Originally Posted by L84sky
If the relay is not faulty, is the PCM energizing the relay? Also, do you mind sharing how you found out the computer is not getting any power?
How could I find out if the PCM is energizing the relay? And I was told that it wasn't getting any power. I don't have a clue to what I'm doing, my father is the one who's doing most the work. All I know is we couldn't connect to the computer with the scan tool. We did an engine, transmission and transfer case swap. The wiring stayed with the engine and everything came out of the same make, model and year as the vehicle I got. We were able to connect to the computer before we swapped everything. We also tried using the computer from the vehicle we took everything out of (which is the one that is currently in the vehicle)
Old Dec 11, 2022 | 7:41 PM
  #12
L84sky's Avatar
Put your finger on the MAIN relay. Turn the key to RUN. The relay should click when you turn the key. Actually both the MAIN and the Fuel Pump relays should energize at the same time. The Fuel Pump relay will then de-energize three seconds later. You should be able to hear the fuel pump motor during those first three seconds.
Old Dec 11, 2022 | 8:15 PM
  #13
R Sadler's Avatar
Okay thank you, I'll give you an update when I can
Old Dec 31, 2022 | 6:18 PM
  #14
R Sadler's Avatar
I was finally able to work on my truck today. We took the dash off and found some chewed wires. Don't know what we did but it it started and we were able to connect to the computer. Hopefully it stays like that, but thank you all for the help
Old Dec 31, 2022 | 6:58 PM
  #15
L84sky's Avatar
Any chance you took pictures of the wires?
Old Dec 31, 2022 | 7:10 PM
  #16
R Sadler's Avatar
Not any clear pictures
but it was one of the wires running to that. It was just stripped to the copper
Old Dec 31, 2022 | 7:57 PM
  #17
L84sky's Avatar
That black box is the A/C compressor control module. Two of the wires go directly to the PCM. Maybe something got shorted out.
Did you notice any of these splices under the dash?
Old Dec 31, 2022 | 8:34 PM
  #18
R Sadler's Avatar
No, i dont think there was anything like that. We were able to get it started before we fixed the wires that were chewed
Old Jan 1, 2023 | 6:52 AM
  #19
L84sky's Avatar
Any idea what the actual problem was?
Old Jan 1, 2023 | 12:18 PM
  #20
R Sadler's Avatar
Unfortunately no
Smashengineering
Sep 7, 2019 1:52 AM
Flpmurphy
Mar 8, 2018 5:38 PM
FlyingOkra
Nov 10, 2010 11:03 AM
78monteripper
Nov 10, 2009 1:24 PM
carol360
Dec 30, 2006 5:40 PM
