Tracker 1989-2004
Platform: CAMI (Suzuki)
Cause for damage to catalyst
Old Oct 14, 2021 | 9:02 PM
Dakota0714's Avatar
Default Cause for damage to catalyst
Hi everyone. Thank you everyone who was helping me out in my other posts regarding the catalytic converter and the O2 sensors.
I read that a contributing factor that may damage the catalytic converter (bank 1/2) could be a blown cylinder. Should I change out the cylinder first instead of the converters to prevent the new catalytic converters from being damaged. Has anyone done this before? I’m guessing if a cylinder was blown, I wouldn’t be able to drive the vehicle, correct? Please and thank you
Old Oct 15, 2021 | 6:28 AM
L84sky's Avatar
Originally Posted by Dakota0714
I read that a contributing factor that may damage the catalytic converter (bank 1/2) could be a blown cylinder....
I'm assuming you mean blown head gasket. If so, your mechanic can test for that with a compression test.
Here are the things most likely to cause premature converter failure:
Reasons For A Converter Failure (bobsmuffler.com)
Catalytic Converter Problems | Walker Exhaust Systems
Catalytic Converter Failure: 3 Common Causes (napaonline.com)
What Causes Catalytic Converters to Fail? - News | Viper Motorsports in Weatherford, TX, Fort Worth, TX, and Mineral Wells, TX
Old Oct 15, 2021 | 8:48 PM
if the convertor is plugged...it probably got hot from a misfire or leaking injector.
bad fuel trim kill convertors.
if the only symptom you have is a low efficiency dtc and everything else is working normally....it could be just a tired old 20yo convertor. that don't last forever.
Old Oct 17, 2021 | 2:29 AM
oilcanhenry's Avatar
Nothing ever does, including us. lol!
I'm surprised my 98' K-1500 Chevy Catalytic Convertor is still working well.
Old Oct 18, 2021 | 11:34 AM
Domino3665's Avatar
You REALLY need to decide how much you like this vehicle. ($$$) 😬
Kael
10
Jan 28, 2022 10:37 PM
ole
Jun 5, 2019 10:33 AM
djomlas
Feb 15, 2016 11:10 PM
Nathan Kolton
Sep 17, 2012 11:28 AM
nervousmini
Sep 6, 2012 10:33 PM
