Tracker 1989-2004
Platform: CAMI (Suzuki)
Gearshift stuck
Old Mar 15, 2024 | 1:23 PM
melissajallen's Avatar
Angry Gearshift stuck
My gearshift is stuck and won’t go in reverse on my 2000 Chevy tracker 2.0 4x4, please help!
Old Mar 15, 2024 | 3:43 PM
Rednucleus's Avatar
If you are parked on a hill it can sometimes be dificult to get out of park. Maybe have some strong friends rock the vehicle and try to shift - but don't run them over in the process!!
Old Mar 15, 2024 | 5:11 PM
How many miles? Does it have enough trans fluid?
Old Mar 16, 2024 | 1:53 PM
L84sky's Avatar
Does that mean it's stuck in park? If so, you may have a faulty shift-lock circuit.
Follow the instructions below to manually release the shift-lock.
The "return plate" is in the vicinity of the red square.
Old Mar 17, 2024 | 10:32 AM
Thank you so much, will try this! Any idea how to fix, check what first?
Old Mar 17, 2024 | 10:46 AM
L84sky's Avatar
First verify it's a shift-lock problem. Manually release the return plate and ensure the shifter comes out of park. If the shifter goes in every other gear position after it's unlocked you have verified it's a shift-lock problem.
Old Mar 17, 2024 | 10:59 AM
Ok, Tysm!
melissajallen
Feb 17, 2024 7:13 AM
cperrysubic
Feb 18, 2023 10:32 AM
PoorMansPikesPeak
Jan 9, 2019 6:27 PM
Flpmurphy
Mar 8, 2018 5:38 PM
carol360
Dec 30, 2006 5:40 PM
