Tracker 1989-2004
Platform: CAMI (Suzuki)
P0340 code question
Old Aug 29, 2014 | 8:06 PM
java4iv's Avatar
Default P0340 code, camshaft position sensor
I have a 2000 chevy tracker with the 2.0L motor it stopped running tonight and the code said P0340 (camshaft position sensor). My question is what are the chances of this being a timing belt. The vehicle has 116,000 miles on it and it was running good till it just stopped running while I was doing 65 MPH. Tomorrow i will check it out so one more question. what is the easiest way to check the timing belt and the sensor.
Thanks,
Evelyn
Old Aug 30, 2014 | 11:23 AM
java4iv's Avatar
Default broken timing chain
I took the valve cover off and the chain is broken. do the valves get damaged when the chain breaks on this engine?
Old Aug 30, 2014 | 11:43 AM
Make sure there is lubrication getting to the chain. It shouldn't break that soon if it was taken care of. I believe it is an interference motor, but you be lucky and have no damage.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
umoms
Feb 6, 2012 5:45 PM
dgpadp
Feb 22, 2010 7:06 PM
kjr
Dec 12, 2008 11:02 AM
