Tracker 1989-2004
Platform: CAMI (Suzuki)
Replace Power Steering Belt - 2000 Tracker
Old Mar 26, 2022 | 1:27 PM
CliffE's Avatar
Default Replace Power Steering Belt - 2000 Tracker
I have a 2000 Tracker 1.6L without AC. I want to replace the Power steering belt. I don't see any tensioner pulley to loosen the belt so I can take it off, nor do I see a way to pivot the power steering pump. The belt goes around the power steering pulley and crankshaft pulley. Any help I can get with doing this replacement would be super helpful.
Old Mar 26, 2022 | 4:33 PM
oilcanhenry's Avatar
With a Serpentine belt, NO way. Back when Vee-belts were used, yeah you didn't have a tensioner. If you have Serpentine belt, then it must have a tensioner. If I am mistaken you'll have to remove or loosen the power-steering pump. I haven't seen a Vee-belt on a newer vehicle in many years and I own a 1998 K-1500.with a Serpentine belt.
Old Mar 26, 2022 | 8:00 PM
CliffE's Avatar
Well, if there is a tensioner, I don't know where it is. Maybe part of one of the 2 pulley's? I guess I will try to loosen the power steering pump. Not sure what else to do. Strange setup.
Old Mar 27, 2022 | 5:52 AM
L84sky's Avatar
Old Mar 27, 2022 | 9:15 AM
CliffE's Avatar
Originally Posted by L84sky
This is perfect. Thank you!
Old Mar 27, 2022 | 3:23 PM
CliffE's Avatar
OK, the belt is installed but it is loose. I don't see away way to tighten it. Any suggestions?
Old Mar 27, 2022 | 3:46 PM
L84sky's Avatar
The slot for bolt #10 provides the adjustment.
Old Mar 27, 2022 | 4:33 PM
Rednucleus's Avatar
1st, did you check to see if the new belt was the same size as the old? You will need to use some type of pry bar to carefully put tension on the belt before tightening. Note #10 bolt on the bottom is where the tension is applied, so looks like the bottom of the pump pivots away from the motor
Old Mar 27, 2022 | 7:42 PM
CliffE's Avatar
That did the trick. That guy, #10, is very hidden. All good now. Took her at for a short drive. We are in business. Thanks@
Old Mar 27, 2022 | 7:43 PM
CliffE's Avatar
Yep, all good! Everything back together and took her for a spin!!
niceguy88
Uplander
Nov 18, 2019 11:07 AM
subfan597
Jun 18, 2018 3:55 PM
wali110
1988 - 1998 (GMT400)
Mar 6, 2017 3:01 PM
rsolomon515
May 21, 2013 4:38 AM
scott209
Dec 16, 2008 4:35 PM
