Tracker 1989-2004
Platform: CAMI (Suzuki)
Replacing my Valve Cover
Old Dec 22, 2020 | 1:37 PM
Jeremy Byl's Avatar
Default Replacing my Valve Cover
Hi all,
I have a 1999 Chevrolet Tracker - two bolts broke which hold the coils in place. I was able to find a new valve cover to replace from an auto wrecker near which is for a 2003 chevrolet tracker - I wanted to confirm that the 99 chevy tracker and 03 chevy tracker valve covers are compatible?
The wrecker says yes, but my friend has a 03 chevy tracker and looks like the PCV valve is different style and placement, and therefore the valve cover would be different?
Thanks for your reply! Also any quick tips anyone has on replacing valve covers would be helpful!
Cheers!
Jeremy
Old Dec 22, 2020 | 5:09 PM
L84sky's Avatar
In 1999 the two engine options were the 1.6L and the 2.0L. In 2003 the two engine options were the 2.0L and the 2.5L (V6). Are you sure you are comparing apples to apples? Also, any chance a machine shop could remove the two broken bolts?
Old Dec 22, 2020 | 5:45 PM
Jeremy Byl's Avatar
Hi L84sky,
Thanks for the reply! My car is the 2.0L version of the 1999 Chev tracker and the valve cover from the wrecker is the 2.0L version of the 2003 chev tracker - so is the 99 2.0 and the 03 2.0L compatible then?
I did bring it into a mechanic, though just the one, and they said from their past experience when they try to remove the broken bolts, often the bolts and where they screw into is too corroded and worn that the bolt will just continue to break and extracting may cause extra damage. In their opinion the best bet is just to replace the valve cover and the gasket at the same time. What do you think?
I personally hate removing broken bolts, like my nemesis so I thought i'd save myself the hassle and bring it in.
I've found a new valve cover for 70 dollars (35 for the cover and 35 for shipping) as well as rock auto as the gasket for 20 bucks so 100 dollar job.
Old Dec 22, 2020 | 6:09 PM
L84sky's Avatar
According to GM Parts Super Store Chevrolet Tracker Years | GM Parts Online
The '99 and '03 valve covers are the same part number.
Old Oct 7, 2021 | 5:03 PM
Dakota0714's Avatar
Originally Posted by Jeremy Byl
Hi L84sky,
I’m about to cringe after reading this post. I paid $589 to have my valve cover gasket replaced. Did I get ripped off? 😕
I proudly own a 2003 Chevy Tracker, LT, 2.5 L
Old Oct 7, 2021 | 5:29 PM
L84sky's Avatar
The 2.5L has two valve cover gaskets. Did you get both replaced?
Old Oct 8, 2021 | 11:11 AM
Dakota0714's Avatar
The gaskets came in a set. So the garage stated they replaced both of them. I’m guessing that’s the same, correct? Please and thank you. I feel absolutely stupid now.😟
Old Oct 8, 2021 | 12:56 PM
L84sky's Avatar
Removing the valve covers on the V6 is much more involved (and therefore more expensive) than the 4-cylinder engine.
cannesman
Jun 14, 2025 9:50 AM
bcalde07
Jun 18, 2018 9:30 AM
Caitlin
Nov 11, 2016 8:59 PM
alabam5041178
Dec 30, 2014 10:29 PM
hotpapa61
Nov 22, 2014 12:50 PM
