Tracker 1989-2004
Platform: CAMI (Suzuki)
What is this sensor?
Old Oct 31, 2019 | 5:32 PM
stxp64's Avatar
Default What is this sensor?
Hi,
I'm working on the front end of my tracker, just pulled the bumper off and I see that there is something mounted in it near the passenger side. It has two vacuum lines and a three wire connector (red/black/pink). The body of it is black plastic, and there is a metal part that kind of looks like a small electric motor case but without the shaft. There are two wires from the housing to that part (green/red).
Any idea what this is? I can't seem to find it in any manual or diagram.
This is an 01 4wd model.
Thanks
Old Oct 31, 2019 | 6:46 PM
oilcanhenry's Avatar
Originally Posted by stxp64
Hi,
Thanks
Can you post a picture of this part?
Old Oct 31, 2019 | 7:02 PM
stxp64's Avatar
Sorry, that probably would have helped.
I was originally thinking something to do with the airbag system, due to its placement up in the bumper. It seems kind of overkill though, why would vacuum lines be going to a collision sensor? Also, there are no markings or stamps in the sensor with part or manufacturer numbers. Maybe at one time on the metal part but its too rusted now to tell.
Photos
Old Oct 31, 2019 | 8:16 PM
Took a couple minutes to find with Google.
It's not a vacuum line. That's your front axle actuator pump.
GM part# 91175575
Old Oct 31, 2019 | 8:24 PM
stxp64's Avatar
Yes, that's it- thanks!
Also more expensive than I thought.
Old Nov 1, 2019 | 12:07 AM
Cheapest one I found was $250.00 dollars. Hard to believe but there it was.Man that is some serious rust on that part.
Sell ACTUATOR PUMP, AIR PUMP "NEW"($30 Refnd) Fits 4x4 SUZUKI ESCUDO motorcycle in Oldsmar, Florida, United States, for US $255.00
Old Nov 1, 2019 | 4:26 AM
L84sky's Avatar
There's a lot of engineering stuffed into that pump assembly. Probably why it cost so much. It's amazing how much it does with only 3 wires.
Old Nov 1, 2019 | 7:42 PM
Great diagram, but I wouldn't put down $250 USD on that part if I could get a good used one.
Old Nov 1, 2019 | 7:57 PM
Air pumps have soft consumable parts like diaphrams, o-rings and other seals. If you buy a used one you could just end up with something that in not that much better shape than your broken one. Especially if they haven't been made for 20 years. It could just fail on first use. Especially if it's been rotting on a shelf somewhere.
The OP never said it's broken. But if it is then I would attempt to repair it first, or buying a new/reman one failing that.
jameszr2
Sep 26, 2019 8:45 PM
Chuck TieDye
Nov 10, 2016 12:03 PM
nicksurfer
Apr 8, 2016 6:31 PM
Kipp88
Apr 10, 2012 6:42 PM
boghog
Astro
May 25, 2010 12:58 PM
