TrailBlazer 2002-2009
04 LT FUEL LEVEL PROBLEMS
Old Apr 28, 2008 | 1:37 PM
2004LTGUYANDGIRL's Avatar
Default 04 LT FUEL LEVEL PROBLEMS
Old Apr 28, 2008 | 3:27 PM
EvansBlue's Avatar
Default RE: 04 LT FUEL LEVEL PROBLEMS
Check your caps lock bro. Edit your post and make everything properly cased.
Old Apr 29, 2008 | 1:39 PM
rbarrios's Avatar
just from the title.
there issues with gas and the higher levels of sulfur.
it builds up in the tank and on the level sending units resistor.
its what causes the erratic readings. since it cant read the proper resistance- you see that as a funny acting gas gauge.
try running a bottle or 2 of TECHRON FUEL SYSTEM cleaner. (make sure the bottle says it helps with SULFUR buildup).
see if that helps. if it doesnt- then time to replace the level sender.
if it fails to help correct the problem, at least its cleaned the fuel injectors and valves.
ckent1971
Aug 19, 2012 7:26 AM
1sgret
Jul 10, 2011 11:16 PM
goody
Jan 9, 2009 9:21 PM
hussainbaig
Sep 28, 2008 6:00 AM
Jackals7
Jan 24, 2008 7:02 PM
