TrailBlazer 2002-2009
05 Trailblazer electrical issue
Old Jan 10, 2014 | 6:00 PM
Ben Phares's Avatar
Default 05 Trailblazer electrical issue
I killed my battery by leaving the key turned, after jumping it the car runs fine, light work, turn signals and front wipers….but the radio, power door locks, power windows, rear wiper all do not work. I have had the battery and alternator tested, disconnected the battery for a few minutes and all fuses are fine…any thoughts?
Old Jan 10, 2014 | 6:01 PM
Ben Phares's Avatar
Default oh
and the instrument panel works (odometer etc) but the backlight doesn't so you can't see your speed at night
Old Jan 10, 2014 | 9:48 PM
did you check the rear fuse block?
if yes, dealer time as almost all of those components are powered by modules.
Old Apr 2, 2014 | 7:58 PM
bela's Avatar
Default 02 trail blazer electrical problems
I have the same exact problem, All fuses are good front and rear.
Doesn't make sense. Is there a circuit breaker?
thanks
Old Apr 4, 2014 | 9:58 AM
bela's Avatar
Its not the module, is there a fusible link some where?
Old Apr 5, 2014 | 7:58 AM
You know its not the module... how?
the front door locks don't even have fuses let alone fusible links; which I haven't seen on cars in 15 years. The front door locks are POWERED by the driver and passenger door modules...so if you have power and grd to the module but no power out of the module....you may have a module problem. Check for codes set in these modules with a scan tool. The rear locks have a fuse in the rear fuse panel but the command to lock/unlock the rear door is controlled by the bcm
Old Apr 6, 2014 | 7:24 PM
bela's Avatar
I don't have a scan tool so I guess I don't know for sure. I will have it scanned this week. I unplugged the module and it looked good. Nothing looked burnt, so I guess you can't tell by looking at the module or fuses, cause there all good. Its just weird that most everything works except the above mention things from the first post. When I find out I'll let you all know.
Thanks for your help.
Old Apr 10, 2014 | 9:00 PM
vipergg22's Avatar
If you jumpered it wrong then you might have blown the megafuse . Google the image for location ...
Old Apr 11, 2014 | 8:16 PM
bela's Avatar
Vipergg22, thank you so much! It was a 7 dollar mega fuse which replaced the old fusible links.
Old Apr 12, 2014 | 1:38 PM
vipergg22's Avatar
Default fuse
Glad you were able to fix it .
Magnus Sweden
Feb 20, 2011 10:29 AM
cat197633
Mar 4, 2010 12:24 AM
Diesel5479
Feb 9, 2010 3:47 PM
a4chet
Mar 14, 2008 4:06 PM
